Author Topic: fuel pipe check ..... 950013500160M  (Read 10432 times)
Offline SPR
  • 1972 500/4 K1
Re: fuel pipe check ..... 950013500160M
« Reply #15 on: October 01, 2022, 08:21:17 PM »
Undo the locking screw on the outside, remove the fork piece on the inside and the complete mechanism comes out from the inside
Brilliant thanks ... I'll do it when I change the oil and replace the push rod .... and hopefully the 3 x casings that will have been polished by then !!
Simon
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #16 on: October 01, 2022, 09:47:36 PM »
Hopefully if a bit is protruding you can grip it and draw it out. Mine was broken behind the plate with the hole in, the shorter piece had been put in back to front so the shaped end had peened the tip of the long section so it was too fat to come out through the hole.   >:(
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline SPR
  • 1972 500/4 K1
« Reply #17 on: October 15, 2022, 07:47:02 AM »
So ... all set today to swap the push rod / change the casings and refresh the oil / filter etc
Question ... if i have to get the pushrod out from the clutch basket side - is there a torque setting for the nuts when re assembling - I've looked but can't find one ?
Simon
« Reply #18 on: October 15, 2022, 09:12:17 AM »
Tight is the one, there is a generic for 6mm bolts but thats in the book and mine aint here
Offline SPR
  • 1972 500/4 K1
« Reply #19 on: October 15, 2022, 10:23:10 AM »
Thanks Bryan
« Reply #20 on: October 15, 2022, 10:32:30 AM »
I’d go for 3-5 ftlb in the absence of other info…..just saying.
Offline SPR
  • 1972 500/4 K1
« Reply #21 on: October 15, 2022, 11:38:02 AM »
Many thanks :)
Offline Seabeowner
« Reply #22 on: October 15, 2022, 10:11:37 PM »
Manual calls for 7.2-10.1 lbs-ft which seems way high. Never used t wrench, I just tighten em.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #23 on: October 16, 2022, 12:09:37 AM »
Modern manuals say 6.5ftlbs for a 6mm screw and 7ftlbs for a flanged 6mm bolt.
Offline JezzaPeach
« Reply #24 on: October 16, 2022, 08:02:37 AM »
I marked mine with a sharpie and tightened them to the same point apart from one that was probably a bit under in the first place. There are stories of over tightening, including due to torque wrench not working properly, and the basket cracking. They don’t need to be very tight, I got an impression when undoing them, maybe mark and then use a very low torque to ‘test’ the mark.
« Reply #25 on: October 16, 2022, 08:36:10 AM »
Standard torque settings really depends on thread type and bolt type. The higher values correspond with high tensile and fine threads. Go by the  manual, assuming you have the correct fixings.
« Reply #26 on: October 16, 2022, 01:17:37 PM »
I always used my thumb as a guide, I'd put my thumb on the side of the head of the ratchet and when it felt tight enough I'd stop. I checked it once to see how much I was putting on there and it was perfect so I always do that now.
Offline Seabeowner
« Reply #27 on: October 19, 2022, 07:23:10 PM »
1974 manual calls for 6mm hex bolts 5.8-8.7 lbs ft
Clutch spring bolts are especially picked out as higher, up to 10.1.
Maybe one of the many mistakes and maybe they had a lot snapped.
« Reply #28 on: October 19, 2022, 09:21:52 PM »
That would be for for a ‘fine thread’, which they are….
