Author Topic: Grease Nipple Removal  (Read 10371 times)
Offline SPR
  • 1972 500/4 K1
Re: Grease Nipple Removal
« Reply #15 on: October 03, 2022, 08:27:56 PM »
He's (Harry Overton) is on Facebook Ted. He's not far from you in Swadlincote. His work is absolutely stunning. A master of his art. 07861778841
Thanks Julie
I've sent him some pics and a message
Simon
« Reply #16 on: October 04, 2022, 12:11:50 AM »
I'd be interested to see his price, work that good isn't usually cheap. Really must get my bead blasting cabinet working, save me a ton of sanding. £500 for a decent compressor though. Maybe the January sales can help  ;D ;D
« Reply #17 on: October 04, 2022, 01:12:02 AM »
They're dirt cheap over here Ken,  shame I'd have grabbed you one but its a bit much in me hand luggage ;D ;D
Offline SPR
  • 1972 500/4 K1
« Reply #18 on: October 04, 2022, 11:46:00 AM »
One of the casings arrived and it isn't the exact one I ordered as it is missing the two dowels and has some slight crack like marks round the plug thingy :) nothing shows the other side and apart from this is in good condition .... do I send it back or will it be OK
Simon
« Reply #19 on: October 04, 2022, 01:04:24 PM »
They look like stress fractures.
« Reply #20 on: October 04, 2022, 02:53:45 PM »
No, they are casting marks and every clutch casing has them. It's where the alloy was injected into the mould, the plug is the result of where it was cut off the mould.
Do you need the dowels Simon? I've got quite a few stashed around somewhere. A bit of heat and a good pair of pliers and twist them out. Some get ruined as they can rust themselves into situ but 80% come out and can be reused.
« Last Edit: October 04, 2022, 02:57:23 PM by Oddjob »
« Reply #21 on: October 04, 2022, 02:55:08 PM »
Bring it back in bits, a few parts at a time Roo.  ;D ;D
« Last Edit: October 04, 2022, 02:58:24 PM by Oddjob »
« Reply #22 on: October 04, 2022, 03:32:04 PM »
I agree with Ken they look like casting marks - they tend to oil stain and look bad. It would be an odd place for a stress fracture - see if it rubs off with some medium/fine wet & dry.
« Reply #23 on: October 04, 2022, 03:51:12 PM »
Ok mate, should have the complete unit to you in approximately August, is that OK? ;D
Offline SPR
  • 1972 500/4 K1
« Reply #24 on: October 04, 2022, 06:11:13 PM »
Cheers for the input - all off to the polishers tomorrow :)
Another plus - the two NOS push rods arrived today
« Reply #25 on: October 04, 2022, 09:39:55 PM »
Bet they wernt cheap
Offline SPR
  • 1972 500/4 K1
« Reply #26 on: October 05, 2022, 05:21:17 AM »
I suppose it is relative to need :) £45 each
« Reply #27 on: October 05, 2022, 10:17:42 AM »
They seem to be a substantial piece of steel to snap.
« Reply #28 on: October 05, 2022, 01:28:11 PM »
Ends are steel, middle is alloy, it breaks where it joins.
« Reply #29 on: October 05, 2022, 04:32:22 PM »
The alloy was for lightness, aparently the originals were steel and were heavy and caused a lag on clutch engagement
