Author Topic: Getting back to my Honda  (Read 24237 times)
Offline Tomb
Re: Getting back to my Honda
« Reply #15 on: October 03, 2022, 09:43:16 PM »
Next problem- getting seized top rear engine mount bolt out, gonna leave it soaking in WD40 overnight and attack it with heat tomorrow
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #16 on: October 03, 2022, 09:52:45 PM »
Good luck with that Tom! Must be seized in engine mounts? Bit of heat in about the engine lugs will help.
« Reply #17 on: October 03, 2022, 10:43:57 PM »
Tom, do you know Kev and Liz Charman? They frequent the stripand do all sorts of straight line mentalness?
Very well, Kev has just got his Top Fuel rolling chassis ready for the build
small world isnt it? I got them someclutch plates and a cool T spanner for the plugs, lat time I was out here in ther  states. They were mates of an ex of mine. Stayed good friends with them when we finished. I got the bettrer end ofteh deal I reclon ;D ;D
that chassis? ;D ;D
Looksqi
uite a weapon this one!
« Reply #18 on: October 03, 2022, 10:44:05 PM »
« Reply #19 on: October 03, 2022, 11:58:59 PM »
Not being funny here Tom but I've scrapped better bikes than that  ;D ;D ;D
Engine bolt most likely corroded inside the engine not the frame, that could be a BIG problem.
What happened to the left hand side panel, you have an electrical fire under there?
Offline Tomb
« Reply #20 on: October 04, 2022, 12:20:04 AM »
How sad, poor bikes. I prefer saving them.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #21 on: October 04, 2022, 10:46:10 AM »
Apparently plenty of heat and constant wobbling will set most bolts free (I normally add in some choice swearing for full effect). A mate of mine swears by immersion in diesel if it is small enough.
Offline Tomb
« Reply #22 on: October 04, 2022, 01:46:56 PM »
After much heat and hammering, and torsion using socket on the head it’s now turning, so free in the c/cases, but still stuck on the steel spacer. I’ve soaked it and hammered more and heated more. I’ve kept swearing till I really have to but will if necessary 😂
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Offline Tomb
« Reply #23 on: October 04, 2022, 02:05:37 PM »
After hours I’m getting somewhere, small victories 😎
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Offline Tomb
« Reply #24 on: October 04, 2022, 02:27:27 PM »
Finally!!!! Bloody ’ell that was hard work
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #25 on: October 04, 2022, 02:35:59 PM »
Huge swear of appreciation echoes around the garage ;D
Well done Tom 8)
Offline Tomb
« Reply #26 on: October 04, 2022, 05:11:37 PM »
I think smugness was a bit premature as the front bolts in the crank case are solid too. I’m being careful with them as using a breaker bar might spin the nuts and break the cases
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Offline Tomb
« Reply #27 on: October 04, 2022, 05:25:41 PM »
Home made 4 into 1 exhaust could do with a bit of hot metal glue gun work.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #28 on: October 04, 2022, 05:45:21 PM »
Do you mean the bolts holding engine to frame or bolts holding cases together?
« Reply #29 on: October 04, 2022, 05:56:00 PM »
A bit of love needed for sure. Have you tried Plus Gas penetrant oil, its absolutely spot on. Some of the mount bolts and case bolts were practically welded onto my 550, a 24hr soak in that and a bit of heat and not broke and all came out without necking off.
flea bay number 202951224018
EAN 5010352802202
I was surprised how good it is, worth a go if youve heaps of stubborn ones to do Tom.
