Author Topic: NE gasket set, do I need thicker o-rings?  (Read 9183 times)
Offline Seabeowner
Re: NE gasket set, do I need thicker o-rings?
« Reply #15 on: October 25, 2022, 06:58:05 PM »
Other relevant things:
Has the head been skimmed, the depth of the location will be less.
The size of the hole in the head gasket.
May affect The room the O ring has to expand into, May/may not be concentric with the location in the head. Mine vary from 10.8mm to 11mm
O ring sizes available. I found:
5.0 x 2.4,  5 x 2.5,  5 x 3.0
5.23 x 2.62
5.3 x 2.4
5.5 x 2.4,  5.5 x 2.5,  5.5 x 3.0
5.6 x 2.4
How much is recommended as the maximum to compress O ring.
« Last Edit: October 25, 2022, 07:13:38 PM by Seabeowner »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #16 on: October 25, 2022, 09:55:44 PM »
Head skim wont matter as its flat but block skin would as there is a recess
« Reply #17 on: October 26, 2022, 10:05:40 AM »
Just measured the head gasket thickness.
Genuine gasket out of top end set, difficult to measure as Honda put some sort of sticky layer around the hole and it has the effect of sort of bubbling the surface a little but 1.4mm is my best measurement.
My aftermarket kits were both NP ones, Royal Industries NP18004 to be exact. the kits were mixed together but 2 head and 2 base gaskets along with 2 sets of Orings etc, only one of which included the ones for the head oil gallery in question, no sticky layer around the opening, unlike the Honda one but both measured around 1.4mm as well. If anything I'd say they were slightly thicker than OE as they did measure thicker at times, both measured 1.5mm depending on how you read the micrometer.
All the kits were from the 80s maybe even earlier, late 70s maybe.
Offline SteveW
« Reply #18 on: October 26, 2022, 02:28:08 PM »
Thanks for the info guys. Pretty sure my engine has not been apart before, I only did the top end because the valve stem seals had failed. I had no other leaks.
I’m just glad I measured everything, if I had used the gasket set with the o-rings supplied I’m convinced it would have leaked.
I’ll post up my findings once I have the thicker o-rings and it’s back together.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline Seabeowner
« Reply #19 on: October 26, 2022, 07:20:19 PM »
Yes, got right in the earlier post, meant block and typed head. Dunce.
Offline davidcumbria
« Reply #20 on: September 08, 2023, 07:22:34 PM »
Reviving an old thread because I’m in exactly the same quandary. Hope you see this Steve. What size o rings did you fit and have they been ok ?
Offline SteveW
« Reply #21 on: September 08, 2023, 08:16:26 PM »
5 x 2.5 and they have been perfect. Done about 500 miles and zero leaks.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #22 on: September 08, 2023, 11:21:42 PM »
Thanks that’s good to know. Are they nitrile or viton and how thick was the gasket before compression?
Offline SteveW
« Reply #23 on: September 08, 2023, 11:31:47 PM »
Gasket was 1.29mm, original bang on 1.2.
Picture is my order from Simply Bearings, they are Nitrile. I went for the stronger shore rating of 90.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #24 on: September 09, 2023, 08:54:12 AM »
Thanks. My vesrah gasket is 1.4MM thick so an extra 0.1mm thicker than yours. Ithink it makes sense to go for the stiffer 90 shore ring given what’s going on with pressure and heating and cooling. I’ll ditch my cheapo eBay rings of that size and buy the same as you since there is good evidence it works  but the o ring has an even bigger gap to fill with my vesrah gasket. Any problems and I’m going to go original.
« Last Edit: September 09, 2023, 12:29:56 PM by davidcumbria »
« Reply #25 on: September 09, 2023, 03:28:11 PM »
I kept wondering why his head gasket measured 1.2mm when mine, from an original top end gasket set, measured 1.4mm and I spotted the reason in post number 1. His is a CB650 not a CB500/550.
Different gasket so most likely a different thickness, odd though that it still used the same oring.
Offline SteveW
« Reply #26 on: September 09, 2023, 04:46:43 PM »
I’ll be doing the top end on my 550 over the winter so I’ll put up the measurements from that one as well.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #27 on: September 10, 2023, 11:40:00 PM »
A lot of Honda head gaskets have two different thickness. You have the old asbestos type and the non asbestos which are the thicker type.
Always measure up what you have and work out what o'rings are needed for a good seal  ;)
