Author Topic: Chain adjustment question  (Read 5564 times)
Offline SPR
  • 1972 500/4 K1
« on: October 30, 2022, 12:56:43 PM »
When I changed the swingarm I noticed the chain was quite slack so adjusted it on fitting the new swingarm.
Went for a run and came back - checked things over and noticed the chain was again slack - no problem I must have not tightedned everything ... so adjusted again ....
Now something made me spin the wheel and check the play at different points on the chain - and it varies from too tight / too loose / just right
Am I correct in thinking the chain probably wants changing due to stretch etc
If so any recommendations as to make / supplier
Simon
Re: Chain adjustment question
« Reply #1 on: October 30, 2022, 12:58:30 PM »
Possibly chain and sprockets I’d say?
« Reply #2 on: October 30, 2022, 12:59:43 PM »
sounds like it, sounds like you have some tight spots too. Change it, they're not dear. I got one from Mr silver  recently and I dont think it was more than £40.
« Reply #3 on: October 30, 2022, 01:00:28 PM »
meant to say, change the sprockets, too. Cheap as chips ....
Offline SPR
  • 1972 500/4 K1
« Reply #4 on: October 30, 2022, 01:04:41 PM »
Thanks guys ....would my limited skills be able to do the sprockets aswell ?
« Reply #5 on: October 30, 2022, 01:16:14 PM »
Hi Simon sprockets are easy to change, if you can change a swing arm you can do front & rear sprockets make sure you buy ones with the same number of teeth.
No special tools need.
Offline SPR
  • 1972 500/4 K1
« Reply #6 on: October 30, 2022, 01:19:49 PM »
Thanks Ted
I'm assuming it is these three parts
https://www.davidsilverspares.co.uk/CB500K1-FOUR-1972/part_372979/
https://www.davidsilverspares.co.uk/CB500K1-FOUR-1972/part_61491/
https://www.davidsilverspares.co.uk/CB500K1-FOUR-1972/part_61492/
Simon
« Reply #7 on: October 30, 2022, 01:31:50 PM »
They look right - see what Ken or Bryan think before you buy.
« Reply #8 on: October 30, 2022, 01:38:47 PM »
They'll do Simon, however probably cheaper to buy a kit off Ebay to suit. 34T rear sprocket, 17T front, 98 link chain, don't buy an oring chain, a good make like DID with a split link is fine, heavy duty is probably better.
I'll see if I can find one and post a link.
Offline SPR
  • 1972 500/4 K1
« Reply #9 on: October 30, 2022, 01:43:21 PM »
I looked on ebay as the front sprocket at DS is out of stock and I'm baffled ....
Is it this
https://www.ebay.co.uk/itm/225058026779?hash=item346680f51b:g:rfkAAOSwL5Ziwbfg&amdata=enc%3AAQAHAAAAoBm0R9CCClWB097o8eRAt%2FVsnQGY29FxoW8Phbfsv0K9IedUT1LHFvq3lSp8h%2FkgTdPg9Wjcxg8a2SR4l7%2FKNpnvwnpcWbgShL8UFcKwS1%2BTlh4NmsXk8XvL9njjZHSscn9c7KkAgiukpYB9OjeB482X5w%2BVL4rVjLuIAQU6wDxtGShVPWaR6f%2FhNi4jT0XGV7%2Fh32T54q79EDCE9byvyko%3D%7Ctkp%3ABk9SR4j705GFYQ
and do I need some tool to join it .... the one on has an openended link thing on it
Simon
« Reply #11 on: October 30, 2022, 01:47:26 PM »
Last link looks good.
Tsubaki is a decent chain, DID would be better but that can be subjective.
You'd need a chain splitter depending on how may links the chain has when it arrives, however with a split link you can just grind a pin off the chain and join it with the split link.
Offline SPR
  • 1972 500/4 K1
« Reply #12 on: October 30, 2022, 02:18:56 PM »
Ordered - many thanks for the help Ken
« Reply #13 on: October 30, 2022, 09:40:49 PM »
Tsubaki chains were the best I had.
