Author Topic: F2 oil leak  (Read 2137 times)
Offline vonmax
F2 oil leak
« on: October 30, 2022, 01:45:03 PM »
Hi brit living in Belgium getting a slght leak of oil from tacho drive point new seal installed with cup facing into engine assured that is correct way. Still leaks why what is cause and how to cure thanks
Re: F2 oil leak
« Reply #1 on: October 30, 2022, 01:51:59 PM »
You change the oring at the same time?
Where's the leak point, have you identified it yet?
Cup into engine is correct. Writing facing upwards.
If it's the seal possible causes can be worn shaft, seal no longer able to bridge the gap so to speak. If that's the case let me know as I have a few spare shafts lying around. If removing the shaft, don't lose the washer under the head.
Re: F2 oil leak
« Reply #2 on: October 30, 2022, 02:43:47 PM »
Are we talking 750 F2 or 550 F2?
Re: F2 oil leak
« Reply #3 on: October 30, 2022, 03:47:02 PM »
Good point Bryan, I keep forgetting there are 2 F2 models, I just naturally presume it's a 550F2.
Offline vonmax
Re: F2 oil leak
« Reply #4 on: October 30, 2022, 03:51:16 PM »
750 as i put post on 750 page i think but thanks;could i just seal it with gasket sealer and leave 24 hrs or so
Re: F2 oil leak
« Reply #5 on: October 30, 2022, 04:21:13 PM »
Sounds like a bad seal to me then, they are difficult to get right with cover on
