Author Topic: do I need to replace my main bearings  (Read 4967 times)
Re: do I need to replace my main bearings
« Reply #15 on: November 04, 2022, 04:37:56 PM »
Difficult to be certain in pics, i would plastigauge those and if within tolerance reuse them
« Reply #16 on: November 04, 2022, 09:22:44 PM »
Plasitguage is in post no8
« Reply #17 on: November 05, 2022, 01:08:08 PM »
I agree that, if the tolerance checks come good, then they appear in very good shape to continue.
As noted already, the oil conditions so far seem to be impeccable as they look to all purposes "just run in" literally with typical witness marking as expected.
New won't give any tangible benefit given the above.
Offline Sp1john
« Reply #18 on: November 05, 2022, 05:44:37 PM »
I’d say if it’s the first tear down and the crank is in good shape it all depends on your mission and riding intentions. If your are doing a full restoration I’d replace them.If you are happy with the engine and don’t intend to rack up the miles and are operating a strict budget, you might want to use the cash saved elsewhere. I can’t help myself and replaced all shells, main load bearings, dampers and chains….it’s just the way I’m made.
thanks for the advice... the bike will only be doing low mileage  so I will put them back in 👍
« Last Edit: November 05, 2022, 05:47:23 PM by Sp1john »
« Reply #19 on: November 06, 2022, 01:18:33 AM »
Bazinga!
£180 saved to go to the tyre budget............woohoo ;D
