Author Topic: Stainless split exhaust collets  (Read 6897 times)
« on: November 14, 2022, 10:54:35 PM »
For saying how rust and manky they get is anyone making SS
 exhaust collets for old Honda's at sensible money?
Re: Stainless split exhaust collets
« Reply #1 on: November 14, 2022, 10:59:52 PM »
I wire brushed mine clean, then sprayed them with zinc high temperature paint,
Think it was made by Rustoleum
« Reply #2 on: November 15, 2022, 06:33:02 AM »
I went that route. I soaked them for a few days in a derusting agent the name of which I can’t recall, polished them off with a rotary wire brush, wiped them off with acetone then painted them in very HT paint. It won’t last, but it smartened them up for a while. Might even last longer than when they were new.
« Reply #3 on: November 15, 2022, 09:49:06 AM »
After wire brushing off the worst I've left mine in Evaporust for a week. A few of them have out of shape  flanges that I'll need to hammer out.
That's when I got thinking about SS ones - quite a bit of work to shape them I guess.
« Reply #4 on: November 15, 2022, 10:05:37 AM »
I’m sure someone on here was going to have a go at making ss ones, maybe Oddjob?
« Reply #5 on: November 15, 2022, 01:38:00 PM »
No, I sanded them completely flat, then polished them so they shone and they will be getting Cermakrome ceramic coated shortly. Did about 22 of them I think. Spotted them the other day still in the ziplock bag, some have started to go a little rusty in areas but nothing a few minutes with the Dremel won't sort out.
« Reply #6 on: November 15, 2022, 02:10:15 PM »
Giz a look when you get round to it Ken, mine are in the 'to source' box at the min as are pretty shagged out. If youre floggoing them l'll have a set maybe, when  the time comes to get some. Hadnt even thouht that far ahead yet.........
« Reply #7 on: November 15, 2022, 02:30:31 PM »
Your washers were posted today Roo.
How bad are your collets BTW, I threw quite a few away because they were just junk really. I only restored the ones with lots of metal left. Some were so rusty they were paper thin.
« Reply #8 on: November 15, 2022, 02:43:09 PM »
Ted. There is a chap local to me that is making SS collets for 400/4's. I'm just going to reference the part number to see if the fit the 500 as well, because I can't remember 🙄🙄🙄🙄
« Reply #9 on: November 15, 2022, 02:49:36 PM »
Be handy if they are.
« Reply #10 on: November 15, 2022, 02:55:51 PM »
Unfortunately they are not Ted, I've just cross referenced the part number and totally different. I'll ask him if he will be doing 500 ones though.
« Reply #11 on: November 15, 2022, 03:08:16 PM »
There are quite a few 500 & 550 re-builds here so might be worth it for someone to make them.
Noticed the DS ones for a 500 are quite a bit cheaper than the 400 ones.
« Last Edit: November 15, 2022, 03:20:51 PM by McCabe-Thiele (Ted) »
« Reply #12 on: November 15, 2022, 03:17:05 PM »
As you'd expect from anythinf off this bike, they're pretty beat up and very thin. I was going to get soem 'repo cheap' ones when the time came, just havent got reound to it yet as not that important. I was kindly jogged into remembering by Teds post. Still got to find somebody to chrome the pipes first!
« Reply #13 on: November 15, 2022, 03:39:46 PM »
If you give me the measurements Ted, he will make a set of 500 ones for you in SS.
« Reply #14 on: November 15, 2022, 04:32:16 PM »
Any idea of the cost involved Julie?
I would have no idea how to measure one up correctly as there are so many measurements involved - I'd just post him a bent one.  ;D ;D ;D
Some listings seem to show same as 400 see below 40mm x 26 mm.
.https://www.japan-webike.ie/ps/18233-107-000/#!search&p.k=18233-107-000
« Last Edit: November 15, 2022, 06:16:26 PM by McCabe-Thiele (Ted) »
