Author Topic: Desperately need some "77 CB550 carbs.  (Read 6461 times)
Offline Domski
« on: June 27, 2010, 07:44:05 PM »
Hi,
Has anybody got any, or know where I can get some? its a 76 r 77. Cant remember but I do know I need the carbs!
Online Bryanj
Re: Desperately need some "77 CB550 carbs.
« Reply #1 on: June 28, 2010, 07:54:31 AM »
You need to be sure of year and type as 77/78 K are different in majour ways from all the others
Offline captaindonutbikes
« Reply #2 on: June 28, 2010, 10:34:52 AM »
i have a set that needs a rebuild !
cb550k3 cafe
Offline Domski
« Reply #3 on: June 29, 2010, 09:52:53 AM »
Ok, Its def 1977. Thanks but unfortunately mine need a rebuild too and I need ones that are ready to replace.
Offline totty
« Reply #4 on: June 29, 2010, 11:23:33 AM »
Since Domski has turned them down do you mind if I step in?
How much are you after for them? Are they complete and do they just need a strip, clean and seals?
I've got a thread going about bogging in the middle of the rev range and substituting the carbs has been suggested.
« Reply #5 on: June 29, 2010, 02:10:34 PM »
mine are off a 78k and are in need of some serious tlc
the bike ran with them on but they have been apart and will need a complete overhaul and one of the float bowls (no3) leaks and number 4 has had the drain tube blocked by the previous owner with a rivet ! sounds worse than is
i can send you some pictures if you like.  ???
being honest about the condition. i swapped them on mine as i was given a set in better nick, which in irony i completely stripped and rebuilt and am now having trouble starting the engine
cb550k3 cafe
Offline totty
« Reply #6 on: June 29, 2010, 02:20:48 PM »
I'm a little put off by 'serious TLC', but float bowls aren't a problem as I can rob them off the set I'm using.
Mines a 79 reg K. The carbs look almost spotless inside and out but I've replaced all of the ignition and the fault persists so I might as well try different carbs.
Send pics and a price to allan_totty@hotmail.com
Allan
