Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Quote from: Laverda Dave on November 24, 2022, 10:17:45 AMQuote ' I fancied a 650 Bros but our Mayor has killed that idea with his ULEZ charges (soon to be extended to inside the M25 and that will also kill off my VFR unless I want to pay £300 to send it to a ULEZ compliance test that it may fail!). I might look for a CB550, as they have the right amount of power and weight (and ULEZ exempt 😁).Dave, do you know if Historic Motorbikes are exempt - something I haven't thought about until now.....Matt
What content in the last 5 posts has anything to do with Phil's 'Money-Pit' CB350K0 restoration. Nice buy Phil. Do you have the bike at home yet and if so, what state are the mega rare one-piece exhausts in ? Funny, we never got Pine Green bikes here and the USA never got Sardine Blue like we did (both solid colours)Luckily it's not still sporting the hydraulic cam chain tensioner ...what a disaster that was. You will need to check out the rubber diaphragms on the early squared-off bowl carbs. They were notorious for splitting and the pressed together diaphragm / slide assembly expensive to replace although I believe NPR does a replacement kit, which involves cutting off the top plastic retainer ring though.
Hmm .. I wonder !
