Author Topic: CB200 carb issues  (Read 29194 times)
Re: CB200 carb issues
« Reply #105 on: March 25, 2023, 07:30:09 PM »
Yes but you did need some air filters did you not?
We've all done it with petrol engines have we not?
I had a Manta GT/E that was a pig to start in winter having an early design Bosch fuel injection system. I started with plugs then plug caps then plug leads then coil. Changed the fuel filter then finally found a bad connection on the cold start injector. A squirt of contact cleaner - all sorted.
Yes, I think we all do it
Yes, I did need the filters
But it's fun!!
Isn't it
Frustrating at times, but gives great pleasure and satisfaction to get it running sweetly,
Thanks all for your help and support
« Reply #106 on: March 25, 2023, 08:16:48 PM »
I had a Manta GT/E that was a pig to start in winter having an early design Bosch fuel injection system. I started with plugs then plug caps then plug leads then coil then distributor cap.  Changed the fuel filter then finally found a bad connection on the cold start injector. A squirt of contact cleaner - all sorted.
But it's fun!!
Isn't it
« Reply #107 on: March 25, 2023, 09:44:38 PM »
Good to get to the bottom of it John.
« Reply #108 on: March 25, 2023, 09:49:59 PM »
Yes,
It rode really well, comfy, relatively light  ,
Good feeling,
Very enjoyable,
Very glad to have it running nicely
And the summer is coming, perfect for the country lanes,and exploring the local hills
