Author Topic: The modus operandi approaches  (Read 6978 times)
rigwit
« on: June 28, 2010, 08:25:50 PM »
Well. if all the planets are in alignment. and the heebie jeebies  stay away, I should collect the 400-4 tommorow. first job to be done is get it back to an exe employers workshop who has kindly donated me the space and use of for the main and also if its a goer either a boxer size van to pick it up or a small van and plant trailer........  so seccond job (as i know its arunner) is to get it nice and warm and drop the oil. while thats happening   seat tank rear lights indicators wheels  swinging arm front forks  etc  ripped off then while still in frame crack the stator taper seal  and undo the casttelated nut on clutch master drum.. refitting cases after then out it comes... the frame is then being sent to be fine blasted  but while still in the workshop i may as well take up my former employers offer  and  erm weld up all the seams of the main box section frame  also check how gusseting/braceing is  and rectify if need be.... the engine is a total strip down  as it shows  58k on the clock but cannot be varified im assuming it will require a re-bore, see if crank serfices need any light dressing over  and bearings accordingly....... crank is going to be peen stressed and ballanced/ polished.........and the rods pistons gudegeon pins will be weight ballanced for the best match,  head mildly ported and poliched  new valves and guids if needed  all new bearings throught  and seals "o" rings etc....... still toying with rear end go 6082 ally  or high carbon steel for the main billet parts with rect box as members box/box for hoop  and then the central trunnion carrier for the system ive devised.....one thing  there will be plenty of running gear/ and stopping susspension available as i will not be useing the standard 400-4 units, so depending on there condition  anyone in need of such items may have a smile on there face after all. i will keep posted  and take b4  during and compleate pics as it progresses. it will be at least 1 year to get back on road as i,m a sticlker for everything. still beats watching telly or picking your nose  and whats a few expenatives and grazed/ cut fingers.I must be MAD ;D
Offline pae
    • Phil's CB650 pages
Re: The modus operandi approaches
« Reply #1 on: June 28, 2010, 08:49:05 PM »
Sounds interesting, plenty of pics required!
Offline UK Pete
« Reply #2 on: June 28, 2010, 08:56:57 PM »
Good on ya rigwit sounds like an interesting project, be sure to post the pictures on hear as you progress
pete
rigwit
« Reply #3 on: July 01, 2010, 11:12:16 PM »
Well got the bike back to a exe employers yard/worshop just b4 they shut up at 6pm. went in next day  fired her up and dropped oil. then good brush over with traffick film remover and a blast over with there high pressure steam cleaner  and yes it is a steam cleaner not just a pressure washer, planned to go in today to take some low res pics for board  b4  i started stripping her down, but circumstances conspiered to keep me away ( read contractor not comming out at agreed time to do a job)  so to appease myself  ive charged up 2 sets of batteries  for tommorow (friday) and ive just bought an ultrasound cleaner  for the carbs n fiddaly internal parts.
also was looking around for insurance   and loads of well known names did not want to know  after  2 3 hours on phone  i was passed to a specialist insurance broker / company  FOOTMAN JAMES  who will insure a lay up fully comp for theft acc damage etc  and the price
« Last Edit: July 01, 2010, 11:22:33 PM by rigwit »
