Author Topic: stuck in first  (Read 9091 times)
Offline captaindonutbikes
stuck in first
« on: July 01, 2010, 09:43:28 PM »
so she is running sweet but and its a very large but
clicked her into first (has been fine when clicking first and neutral) but the gear has got stuck in first.
before i tear her down to sort it out any suggestions ?
really gutted but trying to remain positive.  :(
cb550k3 cafe
Re: stuck in first
« Reply #1 on: July 02, 2010, 05:54:02 AM »
Probably one of the springs on the change mechanism hidden behind the clutch or if the pedal is floppy the pedal return spring
Re: stuck in first
« Reply #2 on: July 02, 2010, 06:26:51 AM »
completely stuck in first no floppyness
cb550k3 cafe
Offline florence
Re: stuck in first
« Reply #3 on: July 02, 2010, 08:56:19 AM »
I'd try rocking it back an forth with the engine switched off first and see if you can get it to come out.  Next step, take off the cover which goes over the clutch.  At least you can do this with the engine in the frame.  My 350 (same selector and clutch) got stuck in top once and I had to ride it home like that.  When I took the cover off I found that the selector bolt had become loose.  Put it back together and fine thereafter.
If I remember rightly, should you need to split the crankcases, it can be done leaving all the top end, i.e barrels, cylinder head, cam etc in place.
Re: stuck in first
« Reply #4 on: July 05, 2010, 01:10:52 AM »
cb550k3 cafe
Offline florence
Re: stuck in first
« Reply #5 on: July 05, 2010, 09:43:43 AM »
Re: stuck in first
« Reply #6 on: July 05, 2010, 11:08:57 AM »
just realized my own stupidity  ;D
cb550k3 cafe
Offline Yoshi823
  • Biker to the bone...
Re: stuck in first
« Reply #7 on: July 05, 2010, 06:28:07 PM »
One down...four up?
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline Dave M
Re: stuck in first
« Reply #8 on: July 06, 2010, 08:24:20 AM »
Don't keep us in suspense...
Dave
Melbourne.
Re: stuck in first
« Reply #9 on: July 06, 2010, 01:15:54 PM »
Took the clutch case to find the exploded kick start parts loose in the case, thank fully no damage and i was able to get neutral and then all the gears.
and then i lost everything but neutral and second  >:(
to get second i gave it a gentle tap on the selector shaft. but after that no more gears coming through
i believe this is right but could be wrong ( have been many times before!)
cb550k3 cafe
Offline florence
Re: stuck in first
« Reply #10 on: July 06, 2010, 01:46:25 PM »
It can be hard to get all the gears to engage without the engine running, gears need to turn in order to align with the selector dogs.
Being a luddite, I blame electric starts.  If you had kicked it over to start it you would have been alerted to the problem earlier.  :)
Thank heavens it didn't go bang.
Re: stuck in first
« Reply #11 on: July 06, 2010, 05:16:29 PM »
so you think run it to get the gears in ? can't get first at the moment and i think it may we be a selector problem ?
cb550k3 cafe
Re: stuck in first
« Reply #12 on: July 06, 2010, 06:06:48 PM »
spin the clutch shaft and the wheel at the sametime as moving selector drum to try and get gears, with all that fell off there may be selector/gear damage
Offline Yoshi823
Re: stuck in first
« Reply #13 on: July 07, 2010, 11:16:22 AM »
I've had the bottom crankcase off the engine on one of my 550s in the past, without having to remove the top end. It does seem a shame to have to remove the engine for this but it may well be the only way to be able to sort out the gear selectors.
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
