Author Topic: Another paint question  (Read 8059 times)
Offline clinto
« on: December 08, 2022, 07:26:48 PM »
Has anyone had experiance in using the colour Planet Blue mettallic?
Does it require a basecoat/undercoat to bring out the finish?
Having never seen this colour except on pics on internet would appreciate some knowledge.
Ta
Re: Another paint question
« Reply #1 on: December 08, 2022, 08:47:21 PM »
Menno might be able to help, he's probably yer man.
« Reply #2 on: December 08, 2022, 08:50:10 PM »
IMHO it depends what you are painting - generally you get a better finish with a suitable colour primer or undercoat.
« Reply #3 on: December 08, 2022, 09:08:47 PM »
I've used RS paints for supply of paint to the guy who sprays my paintwork including my Planet Blue 750k2 - excellent paint finish using the paint. Use their website for the paint you need including the base coat as a guide
https://www.rsbikepaint.com/en-us/colours.php#makeid=65&modelid=1937&prodyear=1975&colourscheme=3963
« Last Edit: December 08, 2022, 09:14:27 PM by philward »
« Reply #4 on: December 08, 2022, 09:27:04 PM »
Just check with RS as from memory there is a base coat
« Reply #5 on: December 08, 2022, 11:22:36 PM »
From memory all the early metallics were 3 pack
1 metallic
2 clear colour
3 laquer
Offline Menno
  • www.tanklackieren.de
« Reply #6 on: December 10, 2022, 12:03:47 AM »
Planet blue metallic is a straight metallic.
No candy.
So put on a ground coat - for instance grey.
Than simply spraypaint the planet blue metallic.
You can also use a spray can - aerosol for this.
Apply decal and clear.
« Reply #7 on: December 10, 2022, 11:12:39 AM »
No candy.
This kind of info is what sets you aside from all other painters I have used Menno .. the willingness to share tech details and tips .. I phoned another painter I have probably spent £2.5k with over the years and he wouldn't even tell me the Ford white he used on one of my tanks.
I reckon you could make a half decent job of the PBlue metallic with RS Bikepaint aerosol and Spraymax 2k in a can clear. Not a cheap source of materials I know but I know it will yield good results.Aerosols have come on so much in the past ten years. I followed RS's instructions to lay the metallic on and flash off with a powerful hairdryer. Dont get their water based in an aerosol though as the paint splutter on a couple of cans I have had  and ruin what was destined to be a really good job. Ask for COB solvent based paint when you order.
Offline Menno
« Reply #8 on: December 11, 2022, 08:08:15 PM »
Get your decals from Diego... I do.
« Reply #9 on: December 11, 2022, 08:45:26 PM »
No candy.
I'm going to order my paint for the 350k0 over the next few weeks Ash. I'm going for Candy Red/White - did you ever find out what Ford White was used? (to same me paying RS Paints prices for a basic white!).
« Reply #10 on: December 11, 2022, 10:10:30 PM »
 from Phil Ward
[/quote]
I bought some Ford Diamond white base-coat a few months back, as I have a hunch that's what he said he used (he had done someone else's CB350K0 paint-set  prior to doing mine). I am going to do a test panel later this week, as it happens. He did two sets of paintwork Candy red/white and Candy blue-green/white at the same time. One thing I did do, was get him to give me the remains of the tins of candy paints and metallic ground-coat he used on both paint sets. I can get you the colour references if you wish ..the paint was Max-Meyer (solvent based) and Ben Powell, a member here, who works with me, found a firm who sells that paint in  aerosols too.  My CB250K2 Candy Custom Gold/White paint set was painted by a different painter earlier this year and I will compare my test panel with that paint set as well.
« Last Edit: December 11, 2022, 10:14:05 PM by AshimotoK0 »
« Reply #11 on: December 11, 2022, 11:38:01 PM »
That would be good thanks Ash (I assume the Max-Meyer is cheaper than RS and that the reason for using it?)
Offline clinto
« Reply #12 on: December 12, 2022, 04:27:18 PM »
Thanks for info evryone.
Excuse my ignorence ,who is Diego? as I will need correct decals
« Reply #13 on: December 12, 2022, 04:37:25 PM »
Diego is a member on hear who makes and sells quality decals that we all tend to use. Search for 'piki' - he gives a member discount from memory. Contact him via message
« Reply #14 on: December 12, 2022, 06:49:45 PM »
Piki, first class. Good old Post Office destroyed my original order, piki replaced it immediately with no quibble. 5 stars from me👍
