Author Topic: Cb400f Cam chain push bar  (Read 1473 times)
Offline Paulun
« on: December 18, 2022, 12:22:46 AM »
Need a cam chain push bar cb400f.  14550333000 cheers
« Last Edit: December 18, 2022, 01:47:38 PM by Fettler »
Re: Cb400f Cam chain push bar
« Reply #1 on: December 18, 2022, 07:07:54 AM »
You will have to trawl the used parts for that one, there is one person on here who does a lot of 400 parts, may well be same as 250/360 G5 you will have to check part numbers at cmsnl
Offline Paulun
« Reply #2 on: December 18, 2022, 01:44:24 PM »
Hi thanks for reply will keep searching through the posts.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #3 on: December 18, 2022, 02:41:06 PM »
Hi Fettler,
Welcome to the forum - the 400 push bar is also used on the 350/4 (333 model number in middle)
Lots of those were sold in USA and Europe so they might appear on fleabay.
Ian
Offline Paulun
« Reply #4 on: December 18, 2022, 05:49:03 PM »
Thanks Ian great info.
« Reply #5 on: December 18, 2022, 06:30:21 PM »
According to the parts list at cms, getting fed up of looking up parts for other people, the 250/360 G5 is same as 350 four but different to 400 four
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #6 on: December 19, 2022, 07:50:06 AM »
The part number quoted by the OP Fettler is the correct one fitted to 350/4 and 400/4 - I have the genuine Honda parts lists here for both bikes (and the bikes too!) I have no exact knowledge of G5 so cannot comment.  Strange that CMSNL have different p/n??  333 is for 350/4 and obviously preceded 400/4 and many parts are common to both.  400/4 specific parts are 377.
Ian
« Reply #7 on: December 19, 2022, 08:19:16 AM »
350 has two different numbers depending on engine number, one is 396 middle other is 333
