Author Topic: Tank Decal  (Read 5436 times)
Offline Davelu88
Tank Decal
« on: December 28, 2022, 08:38:39 PM »
Hi all , I am doing a 500/ 550 tank and am wondering if you can buy the tank decal including the black area as the only ones I have seen are the white lines and you have to paint the black area yourself. TIA
Re: Tank Decal
« Reply #1 on: December 28, 2022, 08:46:04 PM »
Dont think so, or at least never seen one that way, if you want something different use the gold stripes from the US 550 K2
Offline Davelu88
Re: Tank Decal
« Reply #2 on: December 28, 2022, 10:44:36 PM »
Cheers Bryan I will have a look
Offline SPR
  • 1972 500/4 K1
Re: Tank Decal
« Reply #3 on: December 29, 2022, 07:51:20 AM »
Do you mean the black between the  stripes ?
I'm sure mine were like this when I did the 550 and I got them off Pikki on here and they had the black in between
I would message him and see what he says
Edit - this was mine - the black between the stripes was part of the decal
Simon
« Last Edit: December 29, 2022, 07:54:29 AM by SPR »
Offline Davelu88
Re: Tank Decal
« Reply #4 on: December 29, 2022, 07:20:44 PM »
Hi Simon , yes the black and the stripes as a whole is what I was looking for.
Re: Tank Decal
« Reply #5 on: December 29, 2022, 07:40:32 PM »
The black is always painted on and the decal is the separator between the main colour and the black panel sorry to say Dave. Some people have the stripe painted on rather than use a decal. If it's a decal there is a small bump where it's attached, if it's painted it's generally flat. Either is ok with me but given the choice I'd go for painted lines.
Your pic looks like the later 550K tank rather than the 500K, different type of fuel tap.
Offline Davelu88
Re: Tank Decal
« Reply #6 on: December 29, 2022, 07:48:05 PM »
Hi Ken , yea the pic is just a generic one it was the decal shape I was highlighting,  I have emailed  Piki so see what he says but even if it can be done it may be a challenge  to put on a tank 😉
Re: Tank Decal
« Reply #7 on: December 29, 2022, 09:10:20 PM »
Dave, the key thing that I found when putting my decal on my tank(I position and then fitted the decals for my painter before he painted the black over the gold) was getting the positioning measurements from a member who has the decals in the right place. A member on here provided pictures with measurements from front, back and upper of the tank badge.
I positioned the decal on with small pieces of masking tape. The painter then used fine masking tape to track the decal shape/position and sprayed the black below the masking tape. The decal was then positioned over the joint between the two colours.
I'll try and find the original photo's/measurements that were provided to me by a very experienced/knowledgeable member on here
Re: Tank Decal
« Reply #8 on: December 29, 2022, 09:20:45 PM »
Here you go
Sent from my moto g(50) using Tapatalk
Re: Tank Decal
« Reply #9 on: December 29, 2022, 09:28:43 PM »
And how it turned out in my case
Re: Tank Decal
« Reply #10 on: December 29, 2022, 09:42:05 PM »
The US 550 K2 was a similar stripe but the stripes in gold not white
Offline Davelu88
Re: Tank Decal
« Reply #11 on: December 29, 2022, 09:49:07 PM »
Many thanks , maybe I am being a bit ambitious and should just go with paint  :)
Offline Piki
Re: Tank Decal
« Reply #12 on: December 29, 2022, 11:15:08 PM »
Hello,
as the mates says, the black area must be painted and then apply the stickers.  Due to the rounded shape of the tank it would not fit well such a large sticker…
Offline Davelu88
Re: Tank Decal
« Reply #13 on: December 29, 2022, 11:55:33 PM »
Many thanks  :)
