Author Topic: Lumpy on startup.  (Read 11002 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Lumpy on startup.
« on: January 03, 2023, 11:59:53 AM »
Just an observation that I noticed a wet verdigris deposit on the connectors in the small shroud to the right of the battery (500/4) from the points leading to the coils. It might be worth checking if the feed to the coils is suspect.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Re: Lumpy on startup.
« Reply #1 on: January 03, 2023, 12:15:05 PM »
I'm using silicone grease with components like this.
Virtually waterproof, low/no risk on most materials, very effective in raising reliability of open electric connections.
I use it on HT terminals too (more cars in distributor connections etc) but for these bikes in NGK cap  screw connections and the rubber seal around plug porcelain area. As above, it all but eliminates ingress of any moisture to make them reliable.
« Reply #2 on: January 03, 2023, 02:46:12 PM »
"Verdigris" love the word never heard it before thought it was an anagram or typo at first - thanks again Mr Google.
Every day is a school day are you an English teacher perchance ?. ;D ;D ;D
Now I need to try to think of a sentence with the words Oxymoron, Serendipity & Verdigris in them only used the word Serendipity in context once - it turned out to be a real laugh at work  as they thought I might be a Polymath hiding in plain sight. I should listen to Radio 4 less it's not good for my street cred.
Offline JezzaPeach
« Reply #3 on: January 03, 2023, 02:56:17 PM »
😂😂Ted I must admit I guessed the spelling, and it’s probably the only thing I remember from chemistry O level. Which I didn’t pass……
« Reply #4 on: January 03, 2023, 03:03:07 PM »
Respect  8) 8) 8) 8)
« Reply #5 on: January 03, 2023, 03:21:24 PM »
Isn't verdigris that blue muck associated with copper? like on copper pipes that are old?
That's just off memory, I didn't look it up.
Offline JezzaPeach
« Reply #6 on: January 03, 2023, 03:33:39 PM »
Yes, just a type of oxidation from the copper corroding. I had some on contacts in my old Calibra when the windscreen drain rubber “boot” cloggged up, backed up, and flooded in, saturating the 4in thick foam rubber floor insulation causing condensation everywhere. Not good for car electrics!
Offline rbt1548
« Reply #7 on: February 03, 2023, 11:32:16 PM »
"Verdigris", is that not the girl group King Charles, ( then Prince Charles) , used to like?
