Author Topic: cb400/4 front brake  (Read 4497 times)
Offline gaz172
cb400/4 front brake
« on: February 02, 2023, 09:18:40 PM »
On my 400/4 i did away with the front brake switch and put a stainless goodridge hose from master cylinder to caliper and it passed mot's in the eighties. i am now using it like that now but have been told this is illegal does anyone know if this is true as i was thinking of doing the same with the one i am working on now.
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1994 Ducati 600 monster
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
1978 750 phil read replica
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: cb400/4 front brake
« Reply #1 on: February 02, 2023, 09:28:55 PM »
Gaz, surely the issue is not one of legality, but rather safety? Bikes are dangerous enough without being rear-ended for the sake of a switch.
« Reply #2 on: February 02, 2023, 09:44:12 PM »
Any bike manufactured before 1986 only needs EITHER a front or rear switch, not both.
But personally, I think the use of either brake should go through a switch, it's basic safety common sense.
4.3.2. Switching
Motorcycles first used on or after 1 April 1986 must have a stop lamp that switch on from both brake controls. However, a small number of motorcycles first used from this date were approved with the stop lamp switching on by only one control
« Last Edit: February 02, 2023, 09:54:13 PM by Nurse Julie »
« Reply #3 on: February 02, 2023, 10:19:07 PM »
You can get these or similar
From here to run the same arrangement through this and position it where convenient https://www.demon-tweeks.com/mocal-in-line-brake-light-switch-sender-adaptor-mochar3/
« Reply #4 on: February 02, 2023, 11:03:17 PM »
You can get a banjo bolt with switch built in
Offline gaz172
« Reply #5 on: February 03, 2023, 06:02:19 PM »
4.3.2. Switching
  Thanks julie thats what i thought. always worth checking
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
« Reply #6 on: February 03, 2023, 06:42:02 PM »
Ebay item 203463672328
Offline gaz172
« Reply #7 on: February 03, 2023, 09:25:09 PM »
thanks might give that a try
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
