Author Topic: Copper washer at SS Brahe line attachment?  (Read 2194 times)
Offline alexdecker
« on: February 06, 2023, 03:45:16 PM »
Hey all
I dissasembled my brake recently. When I came to the attachment point in the actual caliper, something seemed to crumble off the little screwed in attachment. I couldn’t figure out if it was some kind of washer or something, as it pretty much disintegrated. Can anyone tell me if there are supposed to be a washer between the caliper and brake lines?
Re: Copper washer at SS Brahe line attachment?
« Reply #1 on: February 06, 2023, 05:31:01 PM »
You'd need to look inside that washer end of that fitting to see if it also matches the caliper port.
Ideally they should have used two opposite taper to seal the joint, which will mean the washer didn't do anything.
However, if that fitting doesn't reach down far enough into the caliper to create that seal with those matching taper, then they may have opted to use the copper washer.
Can you put a picture of the fitting end and inside the caliper where it screws in ?
