Author Topic: Throttle cable stiffness  (Read 8655 times)
Re: Throttle cable stiffness
« Reply #15 on: February 11, 2023, 06:32:13 PM »
Do the clutch cable as well. A little on the speedo and tacho cables also helps but not much or you risk spinning it into the speedo/tacho clock mechanisms.
Offline Multiman
« Reply #16 on: February 11, 2023, 06:37:59 PM »
Will do
Offline 400 Cafe Racer
« Reply #17 on: February 12, 2023, 08:08:53 PM »
Thanks Sesman and Ted.
After sticking it in the vice, applying a little heat, threatening it with long handled grips and lots of trial and error I've got to this.....
Hopefully that will be a lot better on the bike
What I found with mine after I removed it completely for inspection and light oiling, was that there were no kinks or bad bends, but that the inner lining must have melted and expanded causing the inner cable to bind, even after running oil right through.  Worth checking if you stiil have some friction over the full travel before you refit it.
In view if this I have routed the new cable so that it does not go through the "Guide Eye" on the cambox cover, which will reduce any heat transfer from a hot cylinder head vicinity. Checking the cable after a good run confirms it is not getting hot now.
Dennis  :)
Hi Guys,
I was half asleep I think when I read it !!!
It was the CLUTCH CABLE  I was referrring to !!!
Just testing to see if you were all awake  ;D ;D
So just read it in the context of the clutch cable.
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #18 on: February 14, 2023, 09:14:42 AM »
The attached pic from the 400F Setup Manual may help:
That cable guide on the horn is called "Clamp, Clutch Wire" in the parts fiche, but from the pic it seems the throttle cables go through there too.
Offline Multiman
« Reply #19 on: February 14, 2023, 07:20:13 PM »
Offline Athame57
« Reply #20 on: February 17, 2023, 01:14:59 PM »
The throttle cables go through the guide attached to the horn bracket.
I didn't realise that existed until now, does it matter much?
1978 CB400F2 named Elen.
