Author Topic: Tightening sequence for bar clamps ?  (Read 6911 times)
« on: February 16, 2023, 06:10:31 PM »
What is the correct tightening sequence for the handle bar clamps please - looked in my manual not there?
Is it front bolts first then the rear ones?
Re: Tightening sequence for bar clamps ?
« Reply #1 on: February 16, 2023, 06:25:08 PM »
That’s a good question, Ted. I just tightened mine as equally as I could trying to maintain an equal gap between the upper and lower clamps.
« Last Edit: February 16, 2023, 07:23:31 PM by Sesman »
Online Oddjob
« Reply #2 on: February 16, 2023, 07:00:41 PM »
Just do them equally Ted, only the front fork clamps need the front closed up.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #3 on: February 25, 2023, 03:23:14 PM »
Now there's a funny thing!
Just decided to tidy up my bar clamps - just one at a time to save other hassles.  There is clearly a dot at the front and that end is definitely thicker - like the front wheel clamps.  Maybe it's just a Yank spec difference - dunno!
Here's a pic of one of mine - I'm going to treat these just like the front wheel - tighten the front one fully then use the rear as a pinch bolt.
Make up your own minds!
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #4 on: February 25, 2023, 03:26:21 PM »
Makes sense Ian. I always remember front wheel clamps, handlebar switch gear and handlebar clamps always do up the front first and then the back second so any gap is facing backwards.
Offline ST1100
« Reply #5 on: February 25, 2023, 04:00:10 PM »
I was about to mention that there supposed to be punch marks, indicating the [forward] position... typical Honda.
Same for bar, clutch/brake armatures and switches (as well as brake & sift lever) having the default ergos marked...
STOC #637
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: February 25, 2023, 09:23:07 PM »
Appreciate CB750 forks, but guessing the logic carries over…
« Reply #7 on: February 25, 2023, 10:37:27 PM »
My original 77F2 clamps don’t have punch marks…just saying.
« Reply #8 on: February 25, 2023, 10:40:12 PM »
Having written that, if the clamps are stepped then the same logic applicable to the fork clamps must apply.
« Reply #9 on: February 26, 2023, 06:58:07 AM »
I had this vision of equal clamping on the handlebars to allow air flow thus preventing water to accumulate & cause rusting. ;D ;D ;D
Theory does not pass the same test for fork clamps where there is likely to be a much greater threat from water. :-\ :-\ :-\
« Reply #10 on: February 26, 2023, 08:05:18 AM »
It's common engineering practice to design one side to touch, giving datum surface to clamp geometry and make the hole essentially round to match the spindle once that dimensionis established with first fixture (bars are going to be more varied in tolerancing than wheel component) then the second bolt only has to gently apply friction to stop it moving. Because it touches all the way round, if designed correctly, the torque to achieve clamping is relatively small.
It's very similar to the fork stanchion bore/clamp but with the convenience of being able to split it for assembly.
Both tightened to touching is a different joint, the crank mains being one, that doesn't clamp but tries to produce an accurate bore even though it had to be split for access.
« Reply #11 on: February 26, 2023, 08:51:50 AM »
Like I said…if stepped….
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #12 on: February 26, 2023, 03:34:53 PM »
My own 400/4 also has stepped (as Sesman calls them) clamps - don't know about any dots because the washers are hiding that area.  My 350/4 has the row of idiot lights like 500 and that unit has no step so would be tightened evenly front and back.  Not sure if 550/400 for other markets are different arrangement and if life is only 1 day long, News at 10 has just finished, so can't be arsed checking!
(IDHTTL)
Ian
« Last Edit: February 26, 2023, 03:37:25 PM by Orcade-Ian »
1972 Honda CB 350/4
2026 Honda ADV 350
« Reply #13 on: February 26, 2023, 06:31:24 PM »
Hey, Ted. Have a look in the Aladdin’s cave at ‘CB550 F1 set up’ manual and you will have your answer. Had a closer look at my clamps and there is indeed a punch mark on each clamp facing forward.
« Reply #14 on: February 26, 2023, 07:27:45 PM »
Ill take a peek.
