Author Topic: Carb float levels  (Read 13887 times)
Re: Carb float levels
« Reply #30 on: March 21, 2023, 10:42:38 AM »
Correct that man👍
« Reply #31 on: March 21, 2023, 03:17:21 PM »
DR, please read what I said, I said it could vibrate round NOT out, so if the pin is bent it can jam the float from moving, it then vibrates loose and the float can either stick in place or start to work as it should.
Offline Neill C
« Reply #32 on: March 21, 2023, 06:55:15 PM »
I've ordered a new float and pin as I'm taking all the advice I can get. Thanks
Offline Neill C
Re: Air mixture screws
« Reply #33 on: July 09, 2023, 08:36:37 PM »
Are there only 2 air mixture screws on a cb550 carb. One on the left and one on the right or am I not looking hard enough for the other two,
« Reply #34 on: July 09, 2023, 08:49:44 PM »
There is one on each carb body, so you will have 4 in total. Just checking your carbs are Keihin 069a's and not Keihin PD's?
« Last Edit: July 09, 2023, 08:51:22 PM by Nurse Julie »
Offline Neill C
« Reply #35 on: July 09, 2023, 09:01:51 PM »
069a.
I've looked for the other two but can't find them!
« Reply #36 on: July 09, 2023, 09:12:59 PM »
069a.
Have you put the carb bodies on in the correct order? I'm not sure if you can't but if you can find the screw on 2 of the carbs, the other 2 are in the same place on the other 2.
« Last Edit: July 09, 2023, 09:16:24 PM by Nurse Julie »
Offline Neill C
« Reply #37 on: July 09, 2023, 09:19:40 PM »
I haven't taken them apart but when I had the carb off I looker for them but couldn't see them. I'll have to try again!
« Reply #38 on: July 09, 2023, 09:21:23 PM »
Ill take a photo in the morning if you still haven't found them.
Offline Neill C
« Reply #39 on: July 09, 2023, 09:29:37 PM »
« Reply #40 on: July 10, 2023, 09:28:23 AM »
The air / fuel mix screws are these brass ones.
Offline Matt_Harrington
« Reply #41 on: July 10, 2023, 10:07:49 AM »
Neil, did you sort your overflow issue?
Offline Neill C
« Reply #42 on: July 10, 2023, 12:05:37 PM »
Excellent. I found them hiding behind the fuel hose. Thanks for your hepl
Offline Neill C
« Reply #43 on: July 10, 2023, 12:10:14 PM »
Yes. The float bowl overflow went away after a couple of hours riding. It was intermittent at first then went away completely. I'm hoping that the pin on the float sorted itself out and somehow has straightened itself out.
Offline davidcumbria
« Reply #44 on: July 11, 2023, 08:42:49 AM »
Glad it sorted itself out but I have to wonder if the problem was some debris between needle and seat clearing through eventually. Saw earlier in the thread that in line filters in the feed from tank are problematic. To avoid this very problem I was thinking of using them in my rebuild. Is it the consensus view that they cause too much difficulty with flow rate?
