Author Topic: Starting Magnetic Switch connection to main loom  (Read 5575 times)
Offline Eldrick
« on: March 11, 2023, 03:00:27 PM »
 Starting Magnetic Switch has a Red & White cable and Red Cable coming from it. I have just replaced the wiring loom and the new loom has a Box Connector on it. I am sure it is for this cable, however, the old loom had this cable on a 'double bullet' connection. This looks like a patch job to me.
I made a patch with spades to fit the box, the bike started. What I need is a new cable that will fit into this Box connector. I can only presume it is a sealed connection due to the   high voltage passing through it so I don’t want to use the patch I made as the spades could easily touch or arc. Does anyone know where I can get one?
1975 Honda CB400f - Red
Re: Starting Magnetic Switch connection to main loom
« Reply #1 on: March 11, 2023, 03:16:03 PM »
Only 12 volts passing through there. Did you mean high current to the starter motor. If so solid connection is more important than insulation, but it does need insulation of course.
Online Bryanj
« Reply #2 on: March 11, 2023, 05:27:57 PM »
Check where the wires in the loom go to, from memory red/white goes to rectifier and red to ignition switch or fuse box depending on year.
Let me know and i will tell you what to connect where, bike would be helpful as well, and please dont say its in sig details, i like most never look there!
« Reply #3 on: March 11, 2023, 06:05:22 PM »
Is this on a 400 - if it is it looks like the connector that slots into the bottom of the battery box area under the fuse box.
One side is the loom the other is the block connector to the solenoid or fuse box forget which?
Bottom of this photo?
If the block connector is missing Kojaycat sell them.
starter solenoid by Macabe Thiele, on Flickr
« Last Edit: March 11, 2023, 06:21:53 PM by McCabe-Thiele (Ted) »
Offline Eldrick
« Reply #4 on: March 11, 2023, 08:38:54 PM »
400f  (1975) UK
« Reply #5 on: March 11, 2023, 09:36:20 PM »
The photo is of the 400f loom on the left side of the frame.
I think that is the wire you are talking about.
Mine had the female side of the connecter still in place - looking at my bike it goes to the solenoid area so it's probably the live side - wiring diagram will confirm.
As I mentioned previously Kojaycat sell the connectors in pairs, part include the terminals.
Part number is 35858-333-000 Magnetic Sub Cord. Pretty sure you could find a used one or a new one from someone like Electrex.
.https://www.ebay.co.uk/itm/364138067040?hash=item54c851f460:g:REEAAOSwdwZj2KEv&amdata=enc%3AAQAHAAAA8Lor7FnKJ3S%2FRJVhOs8I8jaAhxy8y%2Bf2GAo4I0ITg7XAnMHEL%2FUYF2m12Vyzb8gdaFMl%2FetSAAV7Gg3EWrX3hU%2FqYBYeiRjqusk2vFVkN1xj3Nu1gamSrK3Xo%2FUj4L2JIgGoXjVU%2BV20F7FHUi51NYVlfGkY4RqwXkgT9uKepqeloogQ4f%2FXt%2FJOlcQ4txT4IcF6%2B4VFg9fyiwWAEyCmMM2FF7I4XTcCtYk%2BYJnw7%2BENPjqFjQ1KQxCZKIIfTxf9zrmwL4J92O1QcgdvdvfPLHbdnRmPUITjkZcpnaXhP1v97x0c8IbJCfXy1xbGUI7GBQ%3D%3D%7Ctkp%3ABFBMnsmSr9ph
« Last Edit: March 12, 2023, 10:08:14 AM by McCabe-Thiele (Ted) »
« Reply #6 on: March 12, 2023, 11:41:34 AM »
CSML do a reproduction part - it will be cheaper to make one yourself.
https://www.cmsnl.com/products/sub-cordmagnetic-non-oe_35858333000p/
Offline Eldrick
« Reply #7 on: March 12, 2023, 12:06:04 PM »
I think that 'Sub Cord, Magnetic (non O.e. Japanese Alternative' willl do tthe trick perfectly.Thanks
I just did not  know what to specifically look for.
« Reply #8 on: March 12, 2023, 12:23:28 PM »
If you download the parts manual for the 400 from Aladdin's Cave you can find the part number & description then search it online.
Also if you are not aware this site does a lot of used 400 spares - Steve is a great guy his site does not show prices but he e-mails you one usually within a few hours,
https://www.400fourbits.co.uk/
https://kojaycat.co.uk/epages/950000457.sf/secbb3f9e5f7c/?ObjectPath=/Shops/950000457/Products/US2WW
Kojaycat do connectors like this one - I double checked with them for my model etc
« Last Edit: March 12, 2023, 12:53:58 PM by McCabe-Thiele (Ted) »
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #9 on: March 14, 2023, 09:52:01 AM »
Hi,
Vehicle Wiring Products https://www.vehiclewiringproducts.co.uk do all the bits you'll need, if you decide to make your own.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #10 on: March 14, 2023, 01:31:09 PM »
Bought a number of items from vehicle wiring products, but have never stocked the Japanese classic OE 6.3mm latched connectors
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline SeanFD
« Reply #11 on: March 14, 2023, 01:41:12 PM »
Do you mean these?
https://www.vehiclewiringproducts.co.uk/c-56-multipin-connectors/c-155-6-3mm-blade-multi-connectors/p-429-female-blade-with-latch
The strange thing is they show a 2-way connector, but then give the dimensions for an 8-way one, and there is no choice of 2-, 4-, 6-, or 8-way blocks.
« Reply #12 on: March 14, 2023, 02:17:29 PM »
Kojaycat do them all my previous post link shoes the one with two connectors.
.https://kojaycat.co.uk/epages/950000457.sf/secbb3f9e5f7c/?ObjectPath=/Shops/950000457/Products/US2WW
« Last Edit: March 14, 2023, 03:06:30 PM by McCabe-Thiele (Ted) »
« Reply #13 on: March 14, 2023, 02:33:13 PM »
Do you mean these?
Your link shows the 6.3mm metal terminals only which do fit most 2,3,4,6,8 way plastic shells. As before, vehicle wiring products do not stock the OE Japanese plastic shells.
Current bikes:-
« Reply #14 on: March 14, 2023, 04:10:22 PM »
VWP have have a box of assorted 6.3mm connectors/ blocks and including a crimp tool. Aren t those connector blocks the correct ones or they something else,? :)
