Author Topic: Spark Plug  (Read 12538 times)
Offline Martin6
Spark Plug
« on: March 13, 2023, 07:01:21 PM »
I spent a very pleasant afternoon in the garage today, chasing down my warm tickover issue (off the choke).
A basic question: One thing I noticed, the manual specifies NGK D8ES plugs. David Silver sells  DR8ES and this is what I have on the bike. Does the 'R' mean resistor? I also have 5k-Ohm plug caps. Is it OK to run resistor plugs together with resistor caps?
Thanks, Martin
Re: Spark Plug
« Reply #1 on: March 13, 2023, 07:13:19 PM »
No, you either use resisted plugs OR resisted caps. The usual combination used is D8EA's with NGK resisted plugs.
« Last Edit: March 13, 2023, 07:15:16 PM by Nurse Julie »
Offline Erny
  • CB750K7 CB550K1
Re: Spark Plug
« Reply #2 on: March 13, 2023, 07:14:10 PM »
What I know, that R really means resistor, but not 100% sure. And running resistor plugs with resistor caps is definitely not OK.
You can confirm if plugs have resistor by measuring them with multimeter
CB750K7 US model (1977)
CB550K1 US model (1975)
Re: Spark Plug
« Reply #3 on: March 13, 2023, 07:37:29 PM »
I feel they work fine together,  there's debate to be had but one forum member won't let that happen  ::)
Re: Spark Plug
« Reply #4 on: March 13, 2023, 07:52:34 PM »
Mine works fine with resistors in both….at least for now. I’m also confident that if those on this forum have experienced issues, they certainty exist.
Re: Spark Plug
« Reply #5 on: March 13, 2023, 08:01:57 PM »
Martin has the correct plugs in his bike, as he said the manual states D8ES. The ones David Silver sells are DR8ES. The modern alternative to the D8ES, which NGK stopped making years ago, are the D8EA.
Re: Spark Plug
« Reply #6 on: March 13, 2023, 08:06:01 PM »
Absolutely, I had a right going on with Greenspark after being wrong footed by DS. Do they know? Oh, Greenspark we’re excellent by the way.
« Last Edit: March 14, 2023, 07:54:10 AM by Sesman »
Re: Spark Plug
« Reply #7 on: March 13, 2023, 08:08:38 PM »
Absolutely, I had ar right going on with Greenspark after being wrong footed by DS. Do they know?
DS has been told by hundreds of people on hundreds of occasions 🙄🙄🙄
Re: Spark Plug
« Reply #8 on: March 13, 2023, 08:27:12 PM »
Dear me….I’ll add to the numbers 😁😳
Re: Spark Plug
« Reply #9 on: March 13, 2023, 09:10:05 PM »
Gave up with NGK plugs some years ago now, with too many copies floating about and only use Denso now, and much better spark  ;)
Offline Martin6
Re: Spark Plug
« Reply #10 on: March 13, 2023, 09:23:14 PM »
Unfortunately, i don't have the correct plugs. I have the DR, resistor plugs, as well as the resistor caps. Could this be the cause of my poor running? It starts OK, but needs throttle and dies once the choke is off. Timing and points gap checks out OK. Valve clearances are fine. An afternoon on the carbs tomorrow, but I'll be looking for D8ES plugs from a reputable source.
Re: Spark Plug
« Reply #11 on: March 13, 2023, 09:32:14 PM »
Or take Triggers tip and go alternative….?
Offline Martin6
Re: Spark Plug
« Reply #12 on: March 13, 2023, 09:45:19 PM »
Which Denso plugs? X-24ES?
« Last Edit: March 13, 2023, 09:49:34 PM by Martin6 »
Re: Spark Plug
« Reply #13 on: March 13, 2023, 09:58:08 PM »
24's are fine on a 750 sohc  ;)
Offline Martin6
Re: Spark Plug
« Reply #14 on: March 13, 2023, 10:09:40 PM »
