Carb bench sync
Topic: Carb bench sync (Read 2612 times)
Johnny4428
Carb bench sync
March 14, 2023, 03:51:15 PM »
With the idle screw right out, and ready to set Not 2 as a bench mark, someone on here said an eighth was too much as a guide and to use a sixteenth. Is this correct? Or is it just more critical to just get them all the same.
Nurse Julie
Re: Carb bench sync
March 14, 2023, 03:53:55 PM »
It's more critical to get them all the same John and the slides fully closed when the idle screw is fully backed off. I use the little red pipe from the top of the WD40 can and it's always worked spot on for me. Not sure which carbs you're working on but none I've ever worked on have a master as a bench mark. Maybe that's on the PD's as I've never worked on them.
Last Edit: March 14, 2023, 03:56:40 PM by Nurse Julie
Johnny4428
Re: Carb bench sync
March 14, 2023, 03:58:48 PM »
Thanks Julie! It’s the infamous PD carbs off the 550. I was going to use the vernier depth gauge which is a 16thâ€
Oddjob
Re: Carb bench sync
March 14, 2023, 04:20:34 PM »
You are correct Johnny, the dreaded PD carbs do indeed have a master carb which is the one you sync them all too.
Johnny4428
Re: Carb bench sync
March 14, 2023, 05:47:46 PM »
Cheers Ken! Synced and ready for fitting. New pilots fitted replaced 42’s for 45’s not expecting them to make a lot of difference but a move in the right direction.
Carb bench sync
