Author Topic: rear sprocket size  (Read 4189 times)
Offline mickwinf
rear sprocket size
« on: March 14, 2023, 05:56:40 PM »
Just assembling my rear hub, and I have a new sprocket which is a 37tooth which I believe is a 550 item, the 500 should have a 34 tooth. My question is would it make much difference in the real world if I fitted it?
Re: rear sprocket size
« Reply #1 on: March 14, 2023, 07:16:30 PM »
Improve 0-60 time poorer fuel economy?
« Reply #2 on: March 14, 2023, 07:17:09 PM »
Not a great deal, the primary shaft gear is also different on the 550 and the clutch basket has either more or less teeth as a result, that altered the overall gear ratio but TBH I think Honda put a 37T rear sprocket to improve the standing quarter as there was a lot of competition at the time.
Offline Seabeowner
« Reply #3 on: March 14, 2023, 07:22:31 PM »
I have a little excel sheet for this:
5000 rpm = 64 MPH with 17/34 and 58 MPH with 17/37. (in top). Also depends on tyres slightly.
So will be revving quite a bit higher.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #4 on: March 14, 2023, 07:32:14 PM »
You must also take into account the change in the clutch gearing, as I said they changed it from the 500, IIRC the primary gear had 23T on the 500 but 24T on the 550, that alters the gearing a little.
« Reply #5 on: March 15, 2023, 12:05:12 AM »
Offline mickwinf
« Reply #6 on: March 15, 2023, 01:10:04 PM »
I quite like the idea of quicker acceleration as most of my riding will be on A or B roads so will leave it on, can always change it later.
« Reply #7 on: March 15, 2023, 08:04:36 PM »
What I like about the CB500's standard set 17/34 is that the result in topgear is: 5000rpm = 100km/h, 6000 = 120, 7000 = 140, 8000 = 160 and 9250 = 185km/h.
Offline Seabeowner
« Reply #8 on: March 16, 2023, 06:59:37 PM »
You're right the 500 is 23/64 and the 550, 24/63 primary shaft/clutch basket. Everything else the same: 24/28 Crank/primary shaft and all gear ratios.
« Reply #9 on: March 16, 2023, 07:20:33 PM »
Why I mentioned that was because the gearbox will spin at a slightly different speed on the 550 than on the 500, so the 5000rpm at 64mph might not be true for the 550 even if it had a 34t rear sprocket, with the tacho running off the camshaft the drive train could be turning at a different speed and you'd never know.
On the later Hondas they run the tacho off the mainshaft, you'd get people claiming that changing the front/rear sprockets hadn't made any difference to the speed v revs when in fact if you use GPS speed you'd find the bike running faster or slower for the same revs after swapping sprockets.
