Author Topic: Carbs Install  (Read 26459 times)
Offline Multiman
Re: Carbs Install
« Reply #90 on: April 06, 2023, 01:31:36 PM »
Maybe try a bit of gentle heat?
Could do with heat gun but probably safest in the oven.
Re: Carbs Install
« Reply #91 on: April 06, 2023, 02:11:11 PM »
Heat gun, you want the surrounding metal to get hot, not all of it. If the screw expands faster than the slide it would stick harder.
Offline Martin6
Re: Carbs Install
« Reply #92 on: April 06, 2023, 02:14:59 PM »
None of the screw is showing out the bottom. I didn't know I could still get hold of just the slide. Will look at that.
Re: Carbs Install
« Reply #93 on: April 06, 2023, 02:33:17 PM »
They'll be a few members around with broken 750 carbs, I'm sure one will be able to source one if you ask. Just make sure you quote the number printed on the base, usually
Offline Martin6
Re: Carbs Install
« Reply #94 on: April 06, 2023, 07:27:47 PM »
I put a punch upside down in the vice, sat the screw head on it, then drilled the screw out from the underneath face, tapped it for a larger screw and opened the stay plate hole a fraction. So that bit is sorted.
However, the carb's slide cylinder is quite badly corroded. It is a really stiff slide. Really stiff. So I have found the reason for my stiff throttle and unwillingness to self return. I touched it with some emery cloth and autosol and not much difference. So i hit it a bit harder. Better, but still quite a bit stiffer than 1-3. I've no idea if I've damaged the vacuum / air seal, could well have done. I took off as little as i could, but it was quite bad. I'll crack on at the weekend and then see if it runs OK.
I may need a new carb after all :-\ , I really hope not.
« Last Edit: April 06, 2023, 07:29:26 PM by Martin6 »
Offline Martin6
Re: Carbs Install
« Reply #95 on: April 06, 2023, 07:30:29 PM »
Thanks. Hoping not, I'll soon find out!
Re: Carbs Install
« Reply #96 on: April 06, 2023, 08:11:51 PM »
Ask on the site in the desperately seeking section and see if anyone has a spare carb body for that cylinder, you'll need the carb model number which will be stamped into the body somewhere, on the 500/550 it's on the mounting flange, usually 3 numbers and a letter. If you want cylinder 4 for example you must ask for number 4 carb to replace your existing one.
Offline Martin6
Re: Carbs Install
« Reply #97 on: April 06, 2023, 10:11:57 PM »
Offline Martin6
Re: Carbs Install
« Reply #98 on: April 07, 2023, 12:11:29 PM »
In my carb rebuild kit there is a small o-ring and small washer. Can't for the life of me see where they go. Any ideas?
Re: Carbs Install
« Reply #99 on: April 07, 2023, 12:43:17 PM »
Carb sync port hole screws?
Edit... Or on the top of the carbs? Can you post a photo?
« Last Edit: April 07, 2023, 12:46:55 PM by Nurse Julie »
Offline Martin6
Re: Carbs Install
« Reply #100 on: April 07, 2023, 03:33:16 PM »
Hope this comes through.
Re: Carbs Install
« Reply #101 on: April 07, 2023, 04:21:01 PM »
Is there anything on the air screw, there's usually something on them but the parts book doesn't show it.
Re: Carbs Install
« Reply #102 on: April 07, 2023, 05:09:38 PM »
Float bowl drain oring and inlet manifold vacuum screw? The prize is mine.
Offline Martin6
Re: Carbs Install
« Reply #103 on: April 07, 2023, 05:24:11 PM »
Thank you. Is that the screw that plugs the hole used for vacuum guages?
The prize is a trip to Essex to balance my carbs :D
Re: Carbs Install
« Reply #104 on: April 07, 2023, 05:28:27 PM »
Except the float bowl sealing ring is shown as being alloy in the parts book.
