Author Topic: 550 fuel taps  (Read 3915 times)
Offline gary123
550 fuel taps
« on: March 31, 2023, 11:49:36 AM »
My 550 came with two fuel taps. the one on the right was fitted to it and looks like micky mouse made it. The one on the left is what is shown in the cmsl parts file, but will not fit my tank.
Its an F1 so can anyone point me to what should be fitted. Ta.
Offline gary123
Re: 550 fuel taps
« Reply #1 on: March 31, 2023, 11:52:02 AM »
Offline Orcade-Ian
    • Older Vehicle Web
Re: 550 fuel taps
« Reply #2 on: March 31, 2023, 01:21:17 PM »
Hi Gary,
I have a US spec F1 and the tap fitted to mine is the one on the right of your pic.  I understand that the correct two outlet type is no longer available.  Why doesn't the l/h one fit? That looks like the one on Randakk's bike which I use as reference.
I can't post Randakk's pics, they are over 7mb each and this system doesn't want to reduce them but here's the link to the Orange F1 - you can trawl down to find the tap pics.
https://bringatrailer.com/listing/1976-honda-cb550-f-super-sport/
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline mickwinf
Re: 550 fuel taps
« Reply #3 on: March 31, 2023, 01:22:34 PM »
The original was like the one on the right, but there are a lot of cheap copies out there. Some did have a bigger thread on the tank, 20mm instead of 16mm, i have a spare tank with the larger size and tap is like the left hand one.
Re: 550 fuel taps
« Reply #4 on: March 31, 2023, 03:40:48 PM »
The one on the left is missing it's brass tube, they were brass until about 76 I think and then changed to plastic, if you used the one on the left it wouldn't have any reserve as it runs on the large tube until the fuel hits that level and then you switch to reserve when it  feeds from the bottom of the tube, no tube, no reserve. Both are missing the fuel strainer which fits over the tube, unusual to see the one on the right with screws holding the face plate on, they are usually rivets meaning you can't clean the inside of the tap if it gets dirty in there.
You need to measure the size of the spigot fitted to the tank Gary and order a tap accordingly. It's most likely the tanks been changed for a later one, hence why the correct tap doesn't fit any longer. Check inside the spigot on the tank and see if the filter is stuck inside the tank, remove and clean if it is, they ain't cheap to buy.
« Last Edit: March 31, 2023, 06:24:15 PM by Oddjob »
Offline gary123
Re: 550 fuel taps
« Reply #5 on: March 31, 2023, 05:02:01 PM »
Hi Gary,
Ian
Left hand one doesnt fit because the bras nut is too big, 20mm I think.
Thanks for the link, thats what mine should look like.
Re: 550 fuel taps
« Reply #6 on: March 31, 2023, 05:07:18 PM »
One on the left is same as 550k3 UK
, just a plastic filter on top as Ken says varying inlets to give you main and reserve. I’m quite sure it was the original on the bike.
Offline gary123
Re: 550 fuel taps
« Reply #7 on: March 31, 2023, 05:59:57 PM »
After a bit of searching it seems the larger (left) tap was fitted to F1s but it looks like I have an F2 tank with 16mm fitting. Not a huge deal, I was just concerned that the single outlet might not be enough. I can use the smaller tap I have as it does have a reserve tube and gauze, if I remember what I did with them.
Re: 550 fuel taps
« Reply #8 on: April 01, 2023, 03:03:32 PM »
Keep me in mind if you’re disposing of tap on the left. If your keeping that’s fine!😉
Offline gary123
Re: 550 fuel taps
« Reply #9 on: April 01, 2023, 08:30:58 PM »
Will do, but I probably will keep it, it may come in handy for the next one.
