Partially Restored 74 CB550
4
5
6
7
15
Topic: Partially Restored 74 CB550 (Read 89339 times)
McCabe-Thiele (Ted)
Re: Partially Restored 74 CB550
Reply #60 on:
June 21, 2023, 10:21:40 PM »
Yes it was my old photo showing the parts well spotted - in my defence I did I did say in the text.
This is how mine now looks with the kick start spring in position.
done at last
by
Macabe Thiele
, on Flickr
Last Edit: June 21, 2023, 10:24:31 PM by McCabe-Thiele (Ted)
Link to my full restoration
Oddjob
Reply #61 on:
June 21, 2023, 10:35:02 PM »
I have a nasty suspicion that the spring inside the gear has lost it's strength or is broken, compare Teds pic to yours, gear is much farther out. As you've got to replace the circlip anyway I'd advise checking, maybe post a pic so we can see if anything doesn't look right.
davidcumbria
Such great knowledge and support on here 👍
SOHC Expert
Reply #62 on:
June 22, 2023, 11:33:44 AM »
Teds gap is great ! Never in doubt
Mine( second photo ) is also pretty good compared to the ones in you tube videos. Like you said in your excellent write up below Ken the large soft spring is principally there to stop the ratchet rattling in the at rest open position and doesn’t significantly move the ratchet inboard - it’s the guide path pushing against the pawl on the ratchet as it rotates that does that. I will in any case put a photo of my pre assembly bits up to show I’m not getting that bit wrong.
http://www.sohc.co.uk/index.php/topic,29348.msg281542.html#msg281542
Last Edit: June 22, 2023, 11:35:19 AM by davidcumbria
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own R1100GS, RD350LC YPVS , Yamaha fazer 600, Yamaha XT250, BmwR80 , HondaVT1300, Royal Alloy GT125.
Oddjob
Reply #63 on:
June 22, 2023, 02:58:05 PM »
What strikes me as odd David is that on Teds pics you an clearly see the large spring, on yours you can't. Which makes me wonder why
davidcumbria
SOHC Expert
Reply #64 on:
June 22, 2023, 08:23:45 PM »
The large spring is in there.here is a photo of the parts for assembly today. Also I thought it would be interesting to have a picture of the end circlip. From the left original, first replacement( in and out about 5 times )and the unused new circlip before I fitted it today. [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Last Edit: June 22, 2023, 08:26:46 PM by davidcumbria
davidcumbria
SOHC Expert
Starter gear tab washer
Reply #65 on:
June 22, 2023, 09:03:54 PM »
I was being naughty and used the original tab washer when refitting starter gear to upper case. A tab snapped off when bending back into place so that was a timely warning. Have ordered a new one (90433283000) from DS but they are saying two weeks back order and I fear it could be worse. Anyone found a suitable off the shelf 6 mm tab washer to replace the oem washer ? I have looked but can’t find anything….
https://www.cmsnl.com/honda-cb550-k1-four-1975-usa_model466/washer-lock-6-mm_90433283000/
Last Edit: June 22, 2023, 09:07:07 PM by davidcumbria
Oddjob
Reply #66 on:
June 23, 2023, 12:08:21 AM »
Got a few of them lying around. I'll bung one in the post for you David.
Just something nagging me about that big spring, doesn't look right for some reason. Seems to be stretched out. So long as it works ok I suppose it doesn't matter.
Like the idea of the ziplock on the shaft to keep the washer in place, good idea.
davidcumbria
SOHC Expert
Reply #67 on:
June 23, 2023, 07:26:19 AM »
Many thanks Ken that washer would be a big help. Part of the enjoyment of a restoration is getting to know your bike better and noodling on how little details work. I’ve never really looked into kickstarts before so I find this and our other discussions very interesting.
In other news I ve had to buy a replacement Mainshaft. There was a ridge on a gear tooth that caused the gears to stick when rotating freely in neutral and I got the complete assy for £50 off eBay. Not sure if this was caused when the selector fork dropped out or by the gears being slightly misaligned when the cases were closed without locating the bearing pin. Either way it wasn’t mr Hondas fault but the result of poor engine building.
The amount of fine metal particles inside was horrendous. At one point the cam chain tensioner had dropped off and was found in the sump by the previous top end only rebuilder. He told me bottom end was ok but shells were completely shot and bottom end gloopy bits in the casing plugs and end of main oil passageway were like grinding paste. Then he misfitted the keeper plate for the selector fork shaft so the gearbox jammed completely after my first ride. It’s a story of real misadventure but nothing terminal and satisfying to get sorted with the help on here.
Oddjob
Reply #68 on:
June 24, 2023, 04:02:05 AM »
Just found this trawling the web.
https://www.ebay.co.uk/itm/133766546740?hash=item1f251b8534:g:uvUAAOSwYw9j9nWJ&amdata=enc%3AAQAIAAAAwMMHg%2FBzP172w%2BkSDpT%2FJxAgdT2FrXuG%2BDaJSFG0BPI6pReERbu7xYXHnZA0a3xK1Te5bvFTTbBJrkbmR%2BXD70OHwRF2ExEU9ReG72P31EC6tPB%2FQFy05GWssqeojMX9f%2F0M0UuzVxzrRgm55IGZx343k8N3ZRW5PB2KGRLr4UFt6%2BWVEHe0l%2FFuzRe%2FlqMKfQ801Q6sCabBZnjDilJx9L9%2FUj%2Bc8RfT%2BxG4uBGKjZhn7Vocxy6B7qw1ri6UiIcLsw%3D%3D%7Ctkp%3ABk9SR_TSr7WdYg
Thought you'd like a laugh.
davidcumbria
SOHC Expert
Reply #69 on:
June 24, 2023, 07:41:07 AM »
That’s horrible profiteering , add the postage and vat and you’re looking at 60 quid for a washer that cms had on sale for a couple of euros. I hope we can meet up some time so I can shake your hand and buy you a pint.
davidcumbria
SOHC Expert
Gear Damage
Reply #70 on:
June 24, 2023, 07:48:03 PM »
Replacement used Mainshaft arrived today. Was pleased to find using new shaft all gears now rolling smoothly over each other. Tracked the slight sticking problem on the original gear down to a couple of teeth. Since it is wear lines across the width of the teeth( bit hard to make out in the photo bit the speckly white band is a channel dug out of the tooth - the narrow grey band above and below are the same tooth surface and the vertical banding is the end of the tooth)I think this is more likely due to the incorrect assembly with the unseated bearing location dowels pushing the shafts out of alignment. (And pushing through the casing at the other end when tightened in gorilla mode) Actions have consequences! [ Guests cannot view attachments ]
Last Edit: June 24, 2023, 09:51:09 PM by davidcumbria
davidcumbria
SOHC Expert
This look ok?
Reply #71 on:
June 30, 2023, 01:35:56 PM »
About to join cases.
Does this look ok? The output shaft oil pump bearing hole is vertical ( pin located) though the photo makes it look otherwise.
Last Edit: June 30, 2023, 02:25:49 PM by davidcumbria
Oddjob
Reply #72 on:
June 30, 2023, 02:32:54 PM »
Where's the starter gear on the primary hub?
davidcumbria
SOHC Expert
Reply #73 on:
June 30, 2023, 02:47:22 PM »
Thanks Ken just saw that I needed to put that on too looking at another rebuild.
davidcumbria
SOHC Expert
Reply #74 on:
June 30, 2023, 03:04:38 PM »
Better [ Guests cannot view attachments ]
4
5
6
7
15
