Author Topic: Airbox rubbers orientation  (Read 3718 times)
Offline Matt_Harrington
« on: May 15, 2023, 09:27:09 AM »
Having dismantled the airbox and given everything a good clean, I notice the rubbers (air filter side) as slightly angled. Is there a correct orientation for these? I know I will struggle getting it all together but wanted to check first...
Re: Airbox rubbers orientation
« Reply #1 on: May 15, 2023, 09:38:54 AM »
You should see a small 'bobble' on the flange of the inlet rubber Matt. These line up with the corresponding 'bobble' on the plastic airbox. Get this right and they should align making life simples :)
« Reply #2 on: May 15, 2023, 09:44:06 AM »
I knew there would be an answer! Thanks  :D
« Reply #3 on: May 15, 2023, 09:57:56 AM »
I  agree with Dave - that said it's still a heavy wrestling match to re-assemble - getting all four rubbers to fit - as you will know you get three to fit but a fourth one on 2 or 3 will not as the box distorts.
« Reply #4 on: May 15, 2023, 10:11:14 AM »
Thanks Ted - It's my job for this afternoon! I'll take a chill pill!
« Reply #5 on: May 15, 2023, 11:25:21 AM »
Are'nt they numbered underneath as the only go in one way as per your question? sure they're stamped 1 through 4
« Reply #6 on: May 15, 2023, 12:16:00 PM »
I think that's the carb to engine side where they are numbered Roo.
The ones into the air box have the wider section at the top with the narrower part at the bottom so they sit horizontal to the carbs.
« Last Edit: May 15, 2023, 12:32:08 PM by McCabe-Thiele (Ted) »
« Reply #7 on: May 15, 2023, 12:25:32 PM »
Defo no numbers and original rubbers have the pip for alignment. The repro rubbers have no pip BUT you can orientate the rubber keeping the flat sides vertical. New ones, which arrived today are nice and soft - unlike the original ones which are as hard as bullets. The originals were all at different angles, so PO / mechanics was unaware they were installed with a correct angle/orientation.
I see the inlet manifold rubbers are for 1&4 or 2&3 - I bet mine are wrong as well!!
« Reply #8 on: May 15, 2023, 12:54:45 PM »
Even if you have long fingers you will find it handy to make a small wooden tool so you can press from the inside of the air box to get all four rubbers in place. When I did my 400 rebuild I fitted it with the rear wheel, mudguard & battery box out it was easy that way.
« Reply #9 on: May 15, 2023, 01:02:11 PM »
Ted, I'll attempt the improvised tool method. I've taken a bike apart before to ensure it all fitted OK but I'm not in the mood to do it this afternoon!  ;D
