Author Topic: 500 oil guide B  (Read 2976 times)
500 oil guide B
« on: May 19, 2023, 01:11:24 PM »
The oil guide is a bit out of shape at the end but otherwise seems useable - the earlier type 11203-323-000 is available but priced at a hefty £30.85 to order from DS.
My later engine number (CB500E-2010986) should have 11203-323-010 that appears to be  no longer available.
TBH I do not know what part I have it was retained in the old engine casing by the threaded bolt - manual shows a self taper 5x16 - my casing does not have a 5 mm thread so intend to fit  the correct  taper screw.
The guide looks as though it diverts oil to the main shaft needle roller bearing. Will I be okay to re-fit the oil guide - if not would the earlier part number fit?
'PXL_20230519_113027305 by Macabe Thiele, on Flickr
« Last Edit: May 19, 2023, 01:19:38 PM by McCabe-Thiele (Ted) »
Re: 500 oil guide B
« Reply #1 on: May 19, 2023, 01:34:51 PM »
The end number is usualy a supplier or minor mod so should be fine Ted
Re: 500 oil guide B
« Reply #2 on: May 19, 2023, 01:36:59 PM »
Thanks Bryan.
Re: 500 oil guide B
« Reply #3 on: May 19, 2023, 03:30:41 PM »
If you need either Ted I have both of those, both oil guide and screw and yes it is like a self tapper.
Re: 500 oil guide B
« Reply #4 on: May 19, 2023, 08:00:39 PM »
I have sent you a PM Ken
Re: 500 oil guide B
« Reply #5 on: June 13, 2023, 10:17:09 PM »
I know the self tapper holds the guide - mine looked as though it was also glued on - Hondabond?
Re: 500 oil guide B
« Reply #6 on: June 14, 2023, 12:16:22 AM »
Nope, just the screw.
