500 gearbox shift drum guide - modification ?
Topic: 500 gearbox shift drum guide - modification ? (Read 2862 times)
McCabe-Thiele (Ted)
May 20, 2023, 11:51:09 PM »
I thought I had mislaid the shift drum guide spring & ball even though I'm pretty sure mine did not have either.
Looking in the manual it looks like they modified the system for some reason.
Only one selector drum is listed that strikes me as strange as there are two designs of drum guide.
Should I be looking at changing anything whilst it is still in bits?
Last Edit: May 21, 2023, 12:26:02 AM by McCabe-Thiele (Ted)
Link to my full restoration
Oddjob
Re: 500 gearbox shift drum guide - modification ?
May 21, 2023, 12:48:14 AM »
Only the very early engines got the ball and spring Ted, the rest got a modified bolt which has a lug? on the bottom, a collar goes around this lug. You're almost certain to have that system.
mickwinf
May 21, 2023, 11:14:02 AM »
Ted I had the same thought when I assembled the gearbox on Lazarus. The shifter drum part number is the same as the old 350k and never changed, the indent for the ball is still there but the neutral stop position is sorted at the clutch end. the collar stops any lateral movement.
McCabe-Thiele (Ted)
May 21, 2023, 01:03:09 PM »
TBH Mick I find the gearbox neutral point weird - on the 400 there was the indent for the neutral switch so you knew where you were.
On the 500 I have no idea what part of the drum end should be pointing in.
I'm awaiting the new bearing half clip retaining rings from DS so have been looking at where neutral should be - I suspect its around 7 o clock mark looking at the drum end indent.
Last Edit: May 21, 2023, 03:11:05 PM by McCabe-Thiele (Ted)
May 21, 2023, 03:47:59 PM »
Its where the indent is at the bottom of the hole the retaining bolt is in as the spring and ball were in the centre of the original bolt
