Author Topic: Vacuum leak  (Read 3100 times)
Offline Pauarc
Vacuum leak
« on: June 02, 2023, 12:19:28 PM »
Could this top seal be giving a vacuum leak as it’s damaged
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Offline Martin6
Re: Vacuum leak
« Reply #1 on: June 03, 2023, 10:53:47 PM »
Possibly. A good bit of investigating there.
There is another thin rubber type gasket inside the screw top, so possibly not affecting how it runs.
Offline Pauarc
Re: Vacuum leak
« Reply #2 on: June 04, 2023, 08:47:26 AM »
A mate who used to work for a Honda bike shop in the 70s had some of the top grommets so carb are coming off to try them
Cb750k2
Offline cbxman
Re: Vacuum leak
« Reply #3 on: June 06, 2023, 09:49:20 AM »
Hi Pauarc,
Interesting.  I was wondering about air leaks here.  I don't see a part number for that other than a "Top Set", but the drawing is unclear.  Unlikely, but do have 4 spare parts for sale?
Cheers,
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
Offline Pauarc
Re: Vacuum leak
« Reply #4 on: June 06, 2023, 12:49:33 PM »
I’m going to see my friend I will see if he may have a part number l haven’t fitted them yet but he told me that they just prize and the new ones just push in
Cb750k2
Re: Vacuum leak
« Reply #5 on: June 06, 2023, 03:52:34 PM »
[/quote
One way to ell would be to spray carb cleaner at the top of the carbs whilst running to see if that influences anything and could point to a leak.
Offline cbxman
Re: Vacuum leak
« Reply #6 on: June 06, 2023, 04:16:27 PM »
[/quote
[/quote]
Yes but if have you wear on the rod in a position other than at tick-over, it might be difficult to detect if the seal is worn just enough to leak a bit at that point.
I'm thinking that maybe the most worn part of the rod is when going on off the throttle.  Clutching at straws here!
Cheers,
Jerry
CB360 G5 1975 UK
CB1300 A5, 2005 UK
Re: Vacuum leak
« Reply #7 on: June 06, 2023, 06:32:07 PM »
It could possibly, but to my mind that's just a scraper seal to stop crap getting to the inner seal. I may be wrong though, it has been known. ;D
