Author Topic: 530 chain on late CB750F1/K7/F2 output shaft  (Read 2543 times)
Offline martin_uk
« on: June 03, 2023, 12:03:57 PM »
Hi Guys
Hope someone has come across this before.
My 1978 F1 has the gearbox output shaft with end bolt to retain sprocket rather than the locking plate and 2 bolts.
I know the K7/K8 and F2 had an increased size 630 chain which was heavy and overkill.
I have fitted a 530 chain, but the standard 530 sprocket is 12.7 wide and leaves a gap on end of shaft.
Im look for a 17t 530 sprocket that is 10.7 wide.
Spoke to DS and they can only supply a standard  K7/F2 630 sprocket
Has any one encountered this and know of a supplier?
Martin
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: 530 chain on late CB750F1/K7/F2 output shaft
« Reply #1 on: June 03, 2023, 02:56:54 PM »
I found this incase it helps others, https://www.cb750.com/threads/78-cb750-f2-chain-conversion.7213/
Apparently K7/F2 output shaft is 10mm further out and cover is different.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #2 on: June 03, 2023, 03:08:24 PM »
A 79 CB650 sprocket apparently fits using a 530 chain and is 10.7 wide so have ordered one and will see how it fits.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #3 on: June 08, 2023, 03:59:14 PM »
The sprocket JTF338 17 fits fine and does not overhang end of shaft.
I fitted with flange outwards which lined up teeth with rear sprocket
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
