Author Topic: Front brake bolts torque spec  (Read 7563 times)
Offline alexdecker
« on: June 09, 2023, 05:11:53 PM »
Hey all
Not sure what these are called in the manual, but the two large bolts clamping the front brake parts together - what are the torque specs for those?
Re: Front brake bolts torque spec
« Reply #1 on: June 09, 2023, 05:32:26 PM »
3,4 - 4 kg-m (24,6 - 28,9 lbs-ft) according to p.2 the official Shop Manual Honda CB500-550.
« Last Edit: June 10, 2023, 09:08:06 AM by deltarider »
« Reply #2 on: June 09, 2023, 08:47:11 PM »
Never used one just BT
« Reply #3 on: June 09, 2023, 09:06:40 PM »
Or if from Yorkshire FT, and that’s not finger tight
« Reply #4 on: June 10, 2023, 09:14:44 AM »
The official Shop Manual Honda CB500-550 is found in Aladdin's Cave in a good resolution.
There is one torque spec there that still puzzles me today.
It's about #22: the front wheel axle nut. Early 80s I did torque that nut @ the recommended 5,5 - 6,5 kg-m (39,5 - 47 lbs-ft), only to find out the wheel wouldn't turn anymore. I loosened the nut up again and all was fine.
« Last Edit: June 10, 2023, 09:47:22 AM by deltarider »
« Reply #5 on: June 10, 2023, 10:49:19 AM »
That doesn’t sound right, might be incorrect spacer between bearings? Worth checking out!
« Reply #6 on: June 10, 2023, 11:55:27 AM »
If I'm reading the post right that was 40 years ago so a bit late in the day..
« Reply #7 on: June 10, 2023, 12:22:15 PM »
I just discussed it with a friend who owns a collection CB Fours and restores them. He reasons in principle finger tight is enough as that nut can't go anywhere.
« Reply #8 on: June 10, 2023, 05:13:16 PM »
Certainly there's no way a correctly assembled wheel spindle arrangement should tighten when that is done.
Agree it would point to something being wrong or out of place to do that.
Recognise that the date here may have impact, but believe same bike is still in use ?
More to the "engineering" point in detail though, that eventuality should absolutely not inform how the assembly is set for anyone, now or then. Clearly advice originating from that is false.
« Reply #9 on: June 10, 2023, 08:25:31 PM »
Not only that, it's still the same wheel and as far as I know, bearings were never replaced, unless PO had it done in the three years and first 33.000km he has owned the bike. Why I torqued that nut? Probably to use my then new torque wrench. ;D I must have had my front wheel out at the occasion to replace brake pads or so.
K2-K6, I had thought my English was reasonable, but - not being a native speaker - I have no idea what you are saying. Could you please paraphrase your last two sentences?
« Reply #10 on: June 10, 2023, 10:39:27 PM »
To clarify, if there was  problem with tightening the axle originally (wheel stopped rotation) then that is no a reason for changing  the torque setting away from manual/specification.
The original fault should be investigated and not an adaption made in how it's assembled.
A torque setting is always put there for a specific reason.
