Author Topic: Clutch plates  (Read 20758 times)
Offline Pauarc
Re: Clutch plates
« Reply #30 on: June 30, 2023, 07:50:46 PM »
When you fit keyed washer should it have be loose on shaft I have douts the fin washer was there I think I am going to take the clutch out to find out if it’s there
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Offline Pauarc
Re: Clutch plates
« Reply #31 on: July 01, 2023, 08:58:57 AM »
Just when for a test run to try clutch adjustment a bit better cold but worse when hot 🥵 could it be the oil getting to sticky when hot in the 70s I used 20/50? Any thoughts it has putoline s4 mineral oil 10w40 in now
Cb750k2
Re: Clutch plates
« Reply #32 on: July 01, 2023, 10:43:09 AM »
The oil gets thinner when hot, would be unusual to have a change in that to make it worse as ordinarily the clutch works more consistently when warmed.
It may be wise to remove, inspect and quantify the thrust washers etc to establish if anything is out of order there as characteristics seem odd.
Before any removal it would be worth pulling and pushing the clutch assembly in and out in order to assess if there's any/much end float on there. This is what the thrust washers etc are trying to control to give repeatability in clutch operation.
Offline Pauarc
Re: Clutch plates
« Reply #33 on: July 01, 2023, 11:30:18 AM »
Now I have decided that I’m going to remove clutch and see if I can find something I will see if there’s any end float
Cb750k2
Offline Pauarc
Re: Clutch plates
« Reply #34 on: July 03, 2023, 01:55:50 PM »
I have removed clutch today before I undone central bolts there was slight in and out movement so took out plate stack which 36.5mm in total also springs out 35.5 long most have noted down wrong so in front of basket the spiled washer I can’t find a thing washer where should it be I have put back together maybe a little better no free play in central nut just to try
Cb750k2
Re: Clutch plates
« Reply #35 on: July 03, 2023, 02:14:04 PM »
The thin thrust washer is between the bearing and the basket.
Offline Pauarc
Re: Clutch plates
« Reply #36 on: July 03, 2023, 06:59:17 PM »
I am trying to work out where on the shaft that is have I got to remove central shaft where the basket sits on?
Cb750k2
Offline Pauarc
Re: Clutch plates
« Reply #37 on: July 03, 2023, 07:12:20 PM »
Pic from manual
Cb750k2
Re: Clutch plates
« Reply #38 on: July 03, 2023, 07:27:16 PM »
It just goes on shaft first before putting the clutch basket on, located between back of clutch and bearing.
Re: Clutch plates
« Reply #39 on: July 03, 2023, 07:54:20 PM »
Don't believe a manual. It is number 18 in this link >>> https://www.cmsnl.com/honda-cb750k2-four-england_model14363/partslist/E18.html
Offline Pauarc
Re: Clutch plates
« Reply #40 on: July 04, 2023, 02:01:58 PM »
I have added some pictures I must be missing something I have a 25mm shim
Cb750k2
Re: Clutch plates
« Reply #41 on: July 04, 2023, 06:36:42 PM »
I am not sure what the washer is in picture number 3 you have posted. Can you post a picture of that washer on its own and not on the shaft.
I have just fitted a shaft to a set of crank cases and the thrust washer i was on about is the other side of the bearing so, forget about that one as, you will not even see if on a clutch change
Offline Pauarc
Re: Clutch plates
« Reply #42 on: July 04, 2023, 06:48:59 PM »
Shim washer
Cb750k2
Re: Clutch plates
« Reply #43 on: July 04, 2023, 06:55:41 PM »
« Last Edit: July 04, 2023, 07:00:50 PM by Oddjob »
Re: Clutch plates
« Reply #44 on: July 04, 2023, 07:10:09 PM »
Shim washer
I am not sure were this shim washer has come from. Once everything is in you have a bevelled washer with outside stamped on it, then the clutch locking washer and then the locking nut.
