Author Topic: Clutch plates  (Read 19895 times)
Re: Clutch plates
« Reply #45 on: July 04, 2023, 07:19:42 PM »
This is the clutch that should be fitted to your K2 >> https://www.cmsnl.com/honda-cb750k4-four-1974-usa_model482/partslist/E++09.html
Re: Clutch plates
« Reply #46 on: July 04, 2023, 07:23:41 PM »
Why would a K4 clutch be fitted in a K2?
Offline Pauarc
Re: Clutch plates
« Reply #47 on: July 04, 2023, 07:25:10 PM »
I just can’t workout where you would fit a 25mm shim wash I only put it there to try to find where it would go I have the keyed washer that goes where I tried that shim washer
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Re: Clutch plates
« Reply #48 on: July 04, 2023, 07:26:25 PM »
Part 18 on this diagram
https://images.cmsnl.com/img/partslists/honda-cb750k2-four-england-transmission_bigma000039e18_1229.gif
Why Honda decided to list it on that diagram is beyond me, surely the clutch page would have been far better.
Re: Clutch plates
« Reply #49 on: July 04, 2023, 07:38:09 PM »
That washer is deep inside the engine Ken and it is not a K2 engine it is a K2 bike with a K4 engine.
Re: Clutch plates
« Reply #50 on: July 04, 2023, 07:40:40 PM »
I can not see why you would have this washer in the clutch area. Assemble the clutch back in the engine without it and see if it makes a difference  ;)
Offline Pauarc
Re: Clutch plates
« Reply #51 on: July 04, 2023, 07:45:29 PM »
This is my cb750k2 clutch 1975
Cb750k2
Re: Clutch plates
« Reply #52 on: July 04, 2023, 07:46:08 PM »
Has this engine been apart ? And this shim washer is from inside the gear box ?
Offline Pauarc
Re: Clutch plates
« Reply #53 on: July 04, 2023, 07:49:21 PM »
No not the bottom end that I know off I have done top end
Cb750k2
Offline Pauarc
Re: Clutch plates
« Reply #54 on: July 04, 2023, 07:53:59 PM »
Only got shim because it was I thought it was missing from clutch shaft?
Cb750k2
Re: Clutch plates
« Reply #55 on: July 04, 2023, 07:54:26 PM »
OK, that shim washer looks to be all silvery and new. Most washers in the gearbox and clutch have a black coat to them.
All i can suggest to put the clutch back in without that shim washer .
Re: Clutch plates
« Reply #56 on: July 04, 2023, 07:56:21 PM »
Why would you put something in that should not be there .
Offline Pauarc
Re: Clutch plates
« Reply #57 on: July 04, 2023, 08:28:43 PM »
I am going to put it back together as it was with no shim I will see how clutch is with smallest clearance
Cb750k2
Offline Pauarc
Re: Clutch plates
« Reply #58 on: July 08, 2023, 11:12:10 AM »
Clutch seems to be working better now did about 30miles seem to get worse when it gets hotter could it be oil  what oil do people use is it worth trying 20w50?
Cb750k2
Re: Clutch plates
« Reply #59 on: July 08, 2023, 11:16:48 AM »
Nope, stick to 10w40, you need the thin at cold to lube the top end
