Author Topic: Clutch plates  (Read 20745 times)
Online Oddjob
Re: Clutch plates
« Reply #90 on: July 27, 2023, 03:02:26 PM »
I used to use BP VF7 back in the day, loved that oil. It had so much cleaning detergent in it that working inside the engine was a treat, completely clean inside, no staining of the alloy inside at all, whereas engine run on Duckhams were black inside, never a big fan of Duckhams, preferred Castrol GTX if I couldn't get VF7.
Seem to recall VF7 was either 5/30 or 10/30.
Re: Clutch plates
« Reply #91 on: July 27, 2023, 03:19:16 PM »
When working in the 70's we used silkolene, which we got from Popes in Bristol who were a pushbike shop but also the main Suzuki spares dealer for the sothwest and used to buy an artic load of oil at a time in 5 gall drums
Re: Clutch plates
« Reply #92 on: July 27, 2023, 04:21:31 PM »
Back in the 1970's Silkolene oil based in Belper was good value for money - all made from waste oil collected from mostly local garages - early re-cycling in action.
Offline Pauarc
Re: Clutch plates
« Reply #93 on: July 27, 2023, 06:03:35 PM »
I have. been thinking of changing the main jets to 110 they turned up today
Exhaust are hm341, carbs are 657b, needle set in middle, compression all around 160psi has just had top end rebuild new rings valves re ground, dynas ignition so no points
Carb sync with carbtune pro main jet was 120 slow 40 air screw 1and 1/2 out
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Re: Clutch plates
« Reply #94 on: July 27, 2023, 06:13:13 PM »
A little low psi. Was it rebored ?
Re: Clutch plates
« Reply #95 on: July 27, 2023, 06:20:59 PM »
160 psi sounds pretty healthy to me - what is the original 150-170 psi?
Online Oddjob
Re: Clutch plates
« Reply #96 on: July 27, 2023, 06:24:10 PM »
Did you remember to open the throttle fully when do the compression test?
A lot forget or don't know to do that.
Offline Pauarc
Re: Clutch plates
« Reply #97 on: July 27, 2023, 06:33:40 PM »
No rebore std rings bore was ok
carb not on bike when checked
Cb750k2
Offline Martin6
Re: Clutch plates
« Reply #98 on: July 27, 2023, 06:57:23 PM »
Engine cold?
Offline Pauarc
Re: Clutch plates
« Reply #99 on: July 27, 2023, 07:03:39 PM »
Yes cold and no oil
Cb750k2
Offline Martin6
Re: Clutch plates
« Reply #100 on: July 27, 2023, 07:32:19 PM »
Thanks Ted,so for an old worn motor, like a 1960s Mini,a 50 grade is OK
For a modern tight clearance motor, a 5 is OK for cold starts
So,would a 5 x 40 be ideal for our sohc motors?
If no,why?
I do not have enough knowledge & long term experience  of sohc engines to advise you if a 5W/40 oil would be suitable - I suspect that grade would be fully synthetic so probably no one has done the testing & research to find a true answer based on rigorous testing.
In reality my experience on different oil brands/grades  is anecdotal - we read the adverts & technical specifications and are swayed with a term like contains Zinc or PTFE etc we make  choices that suit our wallet and personal preference's. As has been said before any oil is better than none.
Reverting back to original Honda engine oils as per old handbooks etc  is based on technology that is now 50 or more years old but no one I suspect has explored if a more modern oils are better or backwards convertible across the range.
The idea that a modern synthetic engine oil is worse for your engine than one designed on synthetic technology I find very  hard to accept.
Ted, I'm a member of the Access Norton forum. Some research was done on oils. See the link: https://www.accessnorton.com/Oil-Tests/NortonOil.php
Even if you only look at the first table, half way down, you can see the difference between Royal Purple HPS 20W50  and their HPS 10W40, is an increase in friction and heat, as tested. Just makes me wary of using oil outside the original spec.
I'm not a scientist, nor engineer, so I tend to play it safe. The key thing I find persuasive is, motors manufactured in the '70s used the design, materials and mass manufacturing technologies of their day. Modern oils may well be better manufactured and have superior additives, but the 1970s engines (even before allowing for 50 years of wear) have run for their lives happily using oils in the ranges specified by the manufacturer and were designed using materials, oil pressures, temperature ranges and moving parts tolerances specifically for those oils.
Only my view, I wouldn't be anti synthetic or semi-synth oil use in a freshly (properly) rebuilt motor, provided it is the right spec (viscosity and for use in wet / semi wet clutches), e.g. 10W40 MA01. I'd personally, be a bit more wary of using synthetic in an unknown / high mileage motor (sadly, mine is in that category!). My concern would be whether there's any risk the detergents pull out a few decades of sludge and do damage, before being filtered out. I wouldn't use 5Wxx.
So, I play it safe, stick to the Honda recommendation and listen to the corroborated, long term experience of other owners. But, I'm not knowledgeable or rich enough to experiment myself.  :)
« Last Edit: July 27, 2023, 07:35:25 PM by Martin6 »
Offline Martin6
Re: Clutch plates
« Reply #101 on: July 27, 2023, 07:38:41 PM »
Yes cold and no oil
So will be higher, especially once run in. Did you do the engine work yourself or use someone? I may need someone this winter.
Offline Pauarc
Re: Clutch plates
« Reply #102 on: July 27, 2023, 07:51:03 PM »
Yes I have always worked on all my bike since the 70s away Honda (cb250,cb360,cb400,cb550 cb750 k7 cb750f2n and now CB750k2)
Cb750k2
Offline Martin6
Re: Clutch plates
« Reply #103 on: July 27, 2023, 08:55:22 PM »
Offline Pauarc
Re: Clutch plates
« Reply #104 on: July 28, 2023, 09:37:24 AM »
In the 70s and 80s I used Duckham 20/50 or Castrol GTX20/50 and had no problems
Cb750k2
