Author Topic: The Dreded Rust  (Read 12503 times)
MIKE550/4
Re: The Dreded Rust
« Reply #15 on: July 21, 2010, 04:51:05 PM »
For chrome i have used oven pride ... works great but lethal on your skin
Re: The Dreded Rust
« Reply #16 on: July 21, 2010, 06:04:47 PM »
I like a good bit of test pilot-ry? Pete.
When I saw that suggestion I thought what a good way to do it, I know that in shot blasting that they can use sharper or more rounded grit depending on what there is to remove, although it sounds alarming it is quite a gentle low risk way to do it.
Let us know if it's any good.
Offline UK Pete
Re: The Dreded Rust
« Reply #17 on: July 21, 2010, 08:59:33 PM »
Well the mixer and pea shingle method must have done some good as when i emptied the tank afterwards there was alot of brown dust, but without washing the tank out its hard to say how well its done as the dust has coated the inside so i cant see, i am now looking for the cheapest acid i can get, i have some patio cleaner acid does anyone know if that will do?
Pete
