Author Topic: How to make a simple tool to remove stuck caliper pistons  (Read 23801 times)
« on: June 28, 2023, 09:11:14 PM »
I have never had any problem in removing stuck piston in the brake caliper and have always got them out by turning the compressor up to 300 PSI but, today i was sorting out some calipers that have been in the bottom of a box for years. They would not budge with the air line so, i set too making a tool from old bits that were laying around.
1) you need is a old brake pipe.
2) a hacksaw
3) grease nipple
4) a tap
5) a old copper washer
Re: How to make a simple tool to remove stuck caliper pistons
« Reply #1 on: June 28, 2023, 09:17:08 PM »
Cut the old fitting off the pipe
« Reply #2 on: June 28, 2023, 09:19:07 PM »
Tap the fitting out to take a grease nipple.
« Reply #3 on: June 28, 2023, 09:21:17 PM »
I had to use a copper washer as, the angled nipple was not facing out.
« Reply #4 on: June 28, 2023, 09:23:43 PM »
Lock the bleed nipple off and attach a grease gun to the grease nipple and the piston was forced out.
Very simple tool  ;)
« Reply #5 on: June 28, 2023, 10:21:33 PM »
I just it a plug in the banjo bolt hole with a bolt of the same thread and used a cheap grease gun that I use on the digger rams. It fits the Honda bleed valve and just simply pumped it out. The nipple is sacrificial anyway. Worked a treat and didn’t have to construct anything
These ones wouldn’t blow out either, still came out with an audible pop
Offline robvangulik
  • Honda Fourever
« Reply #6 on: June 28, 2023, 10:30:06 PM »
Same, even if the greasegun thread just goes one turn in the banjo hole the piston will pop out nicely!
« Reply #7 on: June 28, 2023, 10:32:49 PM »
I only have a manual grease gun that wastes more grease than it uses to lubricate.
Same principle but I used an old car master cylinder (old Mini) connected via pipe using the hydraulic pressure to push out any seized piston as my manual grease guns never worked.
Pretty sure an old  bike master cylinder would work as well.
« Reply #8 on: June 28, 2023, 10:47:01 PM »
Mine’s only a pump up manual one, it’s all in the wrist
Must be
« Reply #9 on: June 28, 2023, 11:26:17 PM »
There are many ways to pop a piston out. No risk of damaging the thread and it can go the the oven for 20 minutes to soften the seal and is easy to attach to a hot caliper.
« Reply #10 on: June 29, 2023, 01:17:43 AM »
Must be
And we all know how strong your wrists are, for some unknown reason of course.
Where's Phil when you need him?
« Reply #11 on: June 29, 2023, 01:40:12 AM »
Must be
Pa ha ha haaa, indeed
takes one to know one.
Offline davidcumbria
« Reply #13 on: June 29, 2023, 09:24:58 AM »
I did have one of those but fell victim to being leant out and never getting it back. Still listed on the whitebpard in the w.shop to be replaced. Great bit of kit aren't they?
Offline Matt_Harrington
