Author Topic: Starter reduction gear  (Read 5748 times)
Offline 4wDaz
« on: July 07, 2023, 02:01:11 PM »
Can anyone confirm if it's possible to change the starter reduction gear without splitting the cases? (400/4). I don’t think it can but a customer of mine insists it can be done by just removing the sump, having never tried to do it this way I'm only 99% sure it can't but appreciate any comments
Cheers Daz
Genuine And Aftermarket Motorcycle Parts Supplier
Re: Starter reduction gear
« Reply #1 on: July 07, 2023, 02:15:10 PM »
Depends if there is room to get the shaft out and how mechanical your pet spider is
« Reply #2 on: July 07, 2023, 02:26:24 PM »
If it is possible, a course in Practical Gynaecology is a baseline - I would imagine taking the engine out & inverting it would be the operating position.
Begs the question why does it need replacement and where have the missing metal parts gone if its worn?
Offline 4wDaz
« Reply #3 on: July 07, 2023, 02:39:23 PM »
He reckons it can be done without removing the engine, so not only do you have to be a contortionist you now have to do the job lying on your back.  :o :D
« Reply #4 on: July 07, 2023, 02:44:02 PM »
If he knows so much about it, why isn't he doing it himself 🤣😏🤣🤣
Offline 4wDaz
« Reply #5 on: July 07, 2023, 03:10:09 PM »
;D I know i won't be attempting it  ;)
Offline Herr Supersport
« Reply #6 on: July 11, 2023, 01:24:52 PM »
Maybe this helps - or shows the way. Attention, it is a 550:
http://forums.sohc4.net/index.php/topic,122084.0.html#lastPost
Personally I wouldn't like to go this route. Shure you can wallpaper the entrance through the letterbox but who want's that?
Offline 4wDaz
« Reply #7 on: July 11, 2023, 02:10:16 PM »
Thanks for that, is the 550 engine similar to the 400 apart from the cc ?
« Reply #8 on: July 11, 2023, 02:20:39 PM »
I am pretty sure the sump on a 400 is smaller in terms of length & width so the aperture you are working in will be smaller as a result.
IIRC the 400 sump is a tad deeper.
« Last Edit: July 11, 2023, 02:39:19 PM by McCabe-Thiele (Ted) »
Offline 4wDaz
« Reply #9 on: July 11, 2023, 02:27:18 PM »
I wish him luck  ;D
