Author Topic: speedo adapter plate  (Read 4495 times)
Offline Mcraig1982
« on: July 08, 2023, 10:20:26 AM »
Any where in the uk sell these? postage is £££££
Re: speedo adapter plate
« Reply #1 on: July 08, 2023, 10:25:42 AM »
Only ever seen them forsale in Germany  ;)
« Reply #2 on: July 08, 2023, 10:30:38 AM »
If you want twin disc it may be possible to modify your original drive plate depending on the front hub. Does the hub have two flats on it
« Reply #3 on: July 08, 2023, 10:31:51 AM »
Not a bad price. The one i bought was from the UK and that was £45  ;)
Offline Mcraig1982
« Reply #4 on: July 08, 2023, 10:34:16 AM »
Ive not had a proper look yet & I don't have the facilities to chop the original one down properly. Id rather buy a properly made plate.
The one from Germany looks well made, just costly postage  :-[
« Reply #5 on: July 08, 2023, 10:41:19 AM »
I modified a plate with a vice, hacksaw and file
« Reply #6 on: July 08, 2023, 10:58:05 AM »
Is it for a 500 or 550?
Offline Mcraig1982
« Reply #7 on: July 08, 2023, 11:02:21 AM »
76 500
I think the 500 & 550 are the same ?
« Reply #8 on: July 08, 2023, 11:05:44 AM »
76 500
The forks are different, there is no fitting point for a 2nd caliper arm on the 500 forks. They are completely different forks.
Offline Mcraig1982
« Reply #9 on: July 08, 2023, 11:23:03 AM »
oh really? it looks like it has the bracket on the right side fork leg??
« Reply #10 on: July 08, 2023, 12:21:16 PM »
Not able to zoom in on your right fork leg - if it has a calliper mounting point it should be a mirror image of the left side fork bolt lugs - four in total iirc.
Two top ones that hold fender & top arm pivot, large lower bolt, caliper adjustment bolt hole.
It depends what lower legs have been fitted.
« Reply #11 on: July 08, 2023, 01:32:15 PM »
Thats because its nothing like a standard 500, probably 550 forks, and riding without a mudguard/fork brace is asking for handling problems
Offline Mcraig1982
« Reply #12 on: July 08, 2023, 02:55:36 PM »
? rides fine. Plus it never rains in the uk  ;D
« Reply #13 on: July 08, 2023, 06:03:24 PM »
Wait till you hit a bump in a corner, without the brace the forks flex every which way
Offline robvangulik
  • Honda Fourever
« Reply #14 on: July 08, 2023, 08:20:14 PM »
With that size front tyre handling won't be too good anyway :o
And the speedo will read too (s)low as well...
« Last Edit: July 08, 2023, 08:22:51 PM by robvangulik »
