Author Topic: Won't return to idle/slight oil seep...  (Read 18274 times)
Online Mikep328
Re: Won't return to idle/slight oil seep...
« Reply #30 on: August 09, 2023, 05:06:42 PM »
Thanks Ian. I'll take a look under that cover this weekend and see what's happening.  Hope no major disassembly work will be required to sort out whatever it is.  If such work is required, I'd probably just let it seep for a while and enjoy riding the bike!
Julie, appreciate the talc suggestion; I'll definitely do that!
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #31 on: August 09, 2023, 05:28:21 PM »
The slight oil seep I have does not appear to be from the pan gasket. It is dripping from the cover on the left side of the engine adjacent to the pan and then down the side of the pan.  So based on an earlier post, the suspect is the gear change seal?
I suppose I could use the oil seep to determine if there is oil in the bike as per old BrittBikes - "If it's not leaking it's out of oil!"  But I'd prefer the typical Honda method - no oil leaks at all!
Sounds crazy but I found new oil especially 10w/40 synthetics would leak oil via the rear main seal on cars - after a few days or a 100 miles they would disappear - I put it down to the thin searching  oil & plasticizers that they add to modern oils then fixing the cause.
Online Mikep328
« Reply #32 on: August 11, 2023, 02:19:21 PM »
Good advice re checking instead of ASSuming the oil pan gasket was the leak.  I removed the left side cover and found that the leak is at the lower left (as you face it) of the oil pump.  It seeps immediately upon starting the engine.  no leaks from the oil pressure sender. I'll check the service manual for the procedure to remove/replace the oil pump seal but if anyone has some specific advice re this, don't hesitate to post!
This added several minutes later:  It appears from the service manual that the pump has essentially three Orings - a large one and two smaller ones that appear to fit around the lower bolts AND that the pump can be removed without draining the oil.  Is my reading correct?
« Last Edit: August 11, 2023, 02:36:14 PM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #33 on: August 11, 2023, 02:47:23 PM »
There are 5 O rings in total in the oil pump.
« Last Edit: August 11, 2023, 02:51:59 PM by McCabe-Thiele (Ted) »
« Reply #34 on: August 11, 2023, 02:51:13 PM »
There are 5 O rings in total on the oil pump.
There are 8 in total on the 400 Ted, including the gearbox oil pump O rings.
« Reply #35 on: August 11, 2023, 03:10:19 PM »
Oops it's not a 500 its a 400 they have those extra rings - my Bad - either way more than 3 by quite a few.
TBH I had forgotten just how different the two oil pumps are.
« Reply #36 on: August 11, 2023, 04:16:39 PM »
Try and lean the bike to the right when removing the oil pump in order for any oil to drain back into the sump. That's if you're not dropping the oil that is.
Online Mikep328
« Reply #37 on: August 11, 2023, 05:06:56 PM »
Good idea, will do!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #38 on: August 11, 2023, 05:42:21 PM »
Just a thought if your oil pump is leaking oil - could the cause be linked to something else that has caused the leak?
I'm thinking oil pressure valve, oll filter valve?
« Reply #39 on: August 11, 2023, 05:57:13 PM »
Probably just the age of the orings Ted, if they are original they are really old now.
Online Mikep328
« Reply #40 on: August 11, 2023, 08:39:09 PM »
According to receipts the engine cases were separated to do various work, including a DSS cam chain tensioner "upgrade" so I ASSUME the oil pump was reinstalled with new O rings.  Maybe an Oring wasn't seated properly or moved out-of place during assembly?  In any case, I hope the cause will be obvious and easily resolved with new Orings.
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #41 on: August 11, 2023, 08:58:19 PM »
Doesn't mean they've removed the oil pump though Mike, if it's not needing to do the work they'd have left it in place
« Reply #42 on: August 12, 2023, 12:29:08 AM »
I took one engine apart and the oil pump o-rings were in a hell of a state, had not been replaced, just smeared with orange silicon gasket. Not everybody puts it back together properly. 😣
Online Mikep328
« Reply #43 on: August 12, 2023, 09:22:09 AM »
That's interesting -  Never having done it (or looked up the procedure), I had assumed that the pump had to be removed to split the cases.
Actually, I hope the pump was NOT removed previously.  If it was and is leaking due to some faulty assembly, it will make me wonder about the quality of the considerable engine work that was done...£2,216.85 worth per the receipt!;)
This added a few minutes later:  After leaning the bike to the right for a bit then placing it on the center stand, when the pump is loosened/removed will any oil - other than residual oil in the pump itself - be draining out?  Will I need a catch pan or will a few rags handle it?
« Last Edit: August 12, 2023, 09:31:52 AM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #44 on: August 12, 2023, 09:33:54 AM »
Always best to have a tray and some rags handy Mike. Ideally you need to keep the bike leaning to the right through the process.
