Author Topic: Not sure if this list is correct !  (Read 3597 times)
Re: Not sure if this list is correct !
« Reply #1 on: July 23, 2023, 11:10:41 PM »
Cant read that link, dont got tapatalk
Offline Toko_Jo
« Reply #2 on: July 23, 2023, 11:17:05 PM »
Offline Toko_Jo
« Reply #3 on: July 23, 2023, 11:19:56 PM »
Required      Service Honda   In Vesrah Top/Bottom   Aftermarket Replacement
   Transmission
1   91202-426-003   OIL SEAL (12X25X4.5)    gearshift drum seal   $3.21
1   91202-KFL-841   OIL SEAL (13.8X24X)    gearshift seal   $3.20
1   91205-283-015   OIL SEAL (33X57X7)   countershaft (output sprocket seal)   $6.43
1   91207-374-000   OIL SEAL (34X8)   seal plug (discontinued)   $7.90
1   91306-703-000   O-RING (24.5X1.5)    internal oring on countershaft (disc'd)   $1.96
   Cylinder @ Head
1   91256-096-651   OIL SEAL (4.8X14.5)    tach seal    $3.08
6   91318-300-013   RUBBER, SEALING    head nut seal   $16.68
8   91301-200-000   O-RING (10X1.6)    valve guide oring   $15.44   x
2   91301-426-010   O-RING (4.9X2.5)    head dowel oring   $2.56   x
8   91302-001-020   O-RING (30.8MM)    tappet oring   $17.92   x
4   91302-001-020   O-RING (30.8MM)   intake manifold oring   $8.96   x
4   91304-286-000   O-RING (61.8X2.0)    cylinder sleeve oring   $21.52   x
2   91310-426-000   O-RING (11X2.5)    cylinder to case dowel oring   $6.00   x
1   91310-426-000   O-RING (11X2.5)    tach oring    $3.00   x
4   91319-323-000   O-RING (6X3)    rocker shaft cover oring   $6.12   x
1   12191-426-306   GASKET, CYLINDER    cylinder to case gasket   $12.60   x
1   12251-374-306   GASKET, CYL HD    head gasket   $57.32   x
1   12329-323-000   GASKET, BTHR CVR   breather cover gasket   $6.99   x
1   12391-323-000   GASKET, CYL HD CVR    rocker cover gasket   $30.56   x
4   18291-390-306   GASKET, EX. PIPE   exhaust pipe gasket   $17.48   x
   Crankcase @ Oil Filter
1   91301-MY9-003   O-RING (15X2.5)    oil filter bolt oring   $0.85
1   91316-425-003   O-RING (89X4.5)    oil filter housing oring   $2.57
1   91319-300-000   O-RING (13X2.5)   oil passage plug oring   $3.22
3   94608-40000   O-RING (19.4X2.8 )    oil passage plug oring   $2.10
1   11398-426-000   GASKET, OIL PAN    oil pan gasket (aka oil pump gasket?)   $6.06
   Clutch @ Crankcase
1   91204-286-003   OIL SEAL (18X29X7)    kick start seal?   $2.57
1   91259-VM0-000    OIL SEAL (10X16X4.5)    outer clutch lever seal   $1.80
1   91301-704-000   O-RING (6MM)    inner clutch lever oring   $1.62
1   91354-371-000   O-RING (23X2)   dipstick oring   $1.85
1   11394-390-306   GASKET, R. CRANKCASE    clutch cover gasket (disc'd)   $8.96   x
1   30372-300-300   GASKET, POINT COVER   point cover gasket          $5.89   x
   Camshaft @ Crankshaft
8   12209-333-005   SEAL, VALVE STEM    valve stem seal   $47.52   x
1   91201-300-003   OIL SEAL (30X42X8 )    crank shaft oil seal, rotor side   $7.24
1   91201-323-005   OIL SEAL (30X45X8 )   crank shaft oil seal, points side   $8.34
1   91305-323-000   O-RING (5.8X1.9)    cam chain tensioner o-ring   $1.76   x
   Alternator @ Oil pump
2   15155-323-000   COLLAR, O-RING    oil pump collar (discontinued)   $1.82
2   31206-402-008   O-RING (60X1.4)    oring in starter   $8.16
2   91301-268-020   O-RING (13.6X2.4)    oil pump collar oring   $3.36
1   91302-250-010   O-RING (47X3.2)   oil pump to case oring   $4.20
1   91312-MG7-003   O-RING (24.4X3.1)    starter to case oring   $3.51
1   94608-40000   O-RING (19.4X2.8 )    oil passage cap on pump oring   $0.70
1   11691-323-306   GASKET    alternator cover gasket (aka dyno gasket?)   $7.19   x
1   31282-323-300   GASKET, START MTR CVR   starter motor cover (disc'd)      x
   Oil Pump Internal
1   91305-426-003    O-RING (46x2)    oil pump cover   $4.13
2   91302-377-000    O-RING (15x2.5)    suction and feed     $6.82
   Carburetor
4   16010-323-305   GASKET SET    gasket kit, 1 per carb   $48.68
   Fuel Tank
1   16950-393-015   PETCOCK ASSY.   petcock assembly   $41.43
1   16952-388-015   SCREEN SET   $21.25
1   17534-323-300    GASKET    filler cap
   Wheel
1   DUST SEAL (22X36X8) 91252-300-003 Front wheel dust seal   6.01      AllBalls 30-3601
1   Front wheel seal #2         AllBalls 30-5009
1   OIL SEAL (34X55X9) 90753-283-000 Rear wheel dust seal   8.97      AllBalls 30-5502
Required
8   Multiples  Connecting Rod Bearings
10   Multiples Crank Bearings
   Front Wheel @ Rear Wheel
2   96140-63020 Front Wheel Bearing 6302U         AllBalls 6302-2RS
1   96140-63040-10 Rear Wheel Bearing #1 6304U         AllBalls 6304-2RD-QE6
1   96140-63050-10 Rear Wheel Bearing #2 6305U         AllBalls 6305-2RD-QE6
   Transmission @ Kickstart
1   23931-323-004 Main shaft gear needle bearing (disconitued)
1   25100-374-003 Oil pump bearing (discontinued)
1   91002-KY4-901 Primary shaft left side bearing 63/22
1   91002-283-000 Countershaft bearing 5205
1   91002-286-008 Mainshaft bearing 5205HS (disconitnued)
1   91007-323-000 Gear needle bearing (disconitued)
1   91008-374-003 Shift drum bearing 16005
1   91022-374-003
1   96100-62050-00 Primary Shaft right side bearing (6205)
* CB550 Seals - Gaskets - Bearings.xls (29 kB - downloaded 300 times.)
« Last Edit: March 14, 2011, 04:37:01 pm by q2418130103p »
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
« Reply #4 on: July 24, 2023, 08:14:25 AM »
Interesting list that Jo. Would be worth the 500 expert guys on here checking it out for accuracy  though. I know MarkB on the CB750 Sancast Only group did a similar list in spreadsheet form (Excel) and also one for all of the fasteners that is very useful.
« Reply #5 on: July 24, 2023, 02:12:17 PM »
Given time i will peruse the list, at first glance there is more than you need
Offline Toko_Jo
« Reply #6 on: July 25, 2023, 07:15:14 AM »
Better to inclde more than less .. as long as the information is correct.
