Author Topic: 1975 CB400F "un-cafe"  (Read 33922 times)
Offline ozzybud
Re: 1975 CB400F "un-cafe"
« Reply #30 on: June 18, 2024, 05:09:52 PM »
I have found it difficult to post on this site using my phone. It works fine on the US site for some reason.
  I usually email the pics to myself on Yahoo and use my Laptop.
  It also works if you take a screenshot of the picture and use that.
 Please don't give up. Love the updates and pictures
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline kartin
  • Expat Brit
« Reply #31 on: June 21, 2024, 03:38:25 AM »
Tail fabrication is under way. On my old bike I used a taillight bracket from another Honda but this time I decided just to fabricate that as well. The tail/mudguard might be on the long side but I can shorten it in the future if needed. Will decide once whole thing is together and I can judge the asthetics.
For the front mudguard, to stay true to my original bike, I wanted to go non-chrome. I have one that came with my RD400 (the white one in the pics). The bracket is all wrong, of course, so I was about to carve into it when a genuine 400-4 guard came up on Ebay. The chrome is a little speckled close up but it stands the 2 metre appearance test so for simplicity of fitting,  I'll go with it for now. I may go non-chrome in the future - from memory the one on my old bike was from a CJ250T since the front forks and braking setup is identical to a 400-4 so I'll keep an eye out for one of those.
Next, painting (tank, side panels, tail)...
1975 CB400F, 1977 RD400, 1994 ZXR750
Offline kartin
  • Expat Brit
« Reply #32 on: June 22, 2024, 04:36:57 AM »
Getting closer to looking complete! Since last post, only 2 things out of the ordinary for me as I continued to rebuild:
- even with new bronze bushes, the swingarm had some play i.e. the tube was also worn. I experimented on some scrap tube to see if I could add a layer of weld then turn down to size on my old lathe but my skills are not up to it. As a temp solution, I wrapped some 0.05mm shim stock around the tube ends. This cured the play nicely but obviously this is not a long term solution so I'll search for a new tube.
- the front forks felt very stiff/sticky. I checked for straightness and alignment but it ended up being extremely tight fork boots and a light smear of lubricant helped enormously.
Rattle can paint job came out ok (Rustoleum sunrise red with Spraymax 2k clear - and yes I was careful with correct PPE), although my filler skills are as bad as ever. No matter how careful I am with my sanding blocks, I always seem to end up with the filler level a fraction low such that you see the outline of the filled area through the paint. Anyway, it stands the 3 metre appearance test ok. I did end up shortening the rear mudguard a bit to get the aesthetics to my liking.
Everything else was more or less standard re-furb/re-fit. I pulled the valve cover and thoroughly checked the cams, journals and also the rubber faces of the cam chain tensioner blade and guide. All seems good so as mentioned before, I'll run the engine as is for a bit then see if anything warrants a re-build. It starts and runs and I've been riding it around my neighbourhood. If you recall how bad the front brake cylinder and caliper were, miraculously it works great!
Immediate to-do list is:
- throttle response is a bit fluffy just off idle. Also, the float valves occasionally stick. So, it's off with the carbs for another go through...
- the chain is occasionally flapping against the chain guard so that needs a tweak (the guard is not actually a 400-4 item so it's already a bit of a kluge).
- find some correct mirrors.
- front brake works great once the lever contacts the MC piston but there's quite a bit of wasted lever motion before that happens. I seem to recall using a 1p coin as a shim in my original bike!
- indicator flash rate is far too fast (it's got some generic car item in it) so need to find a proper flasher.
- after a few miles I'll go over the valve clearance, timing, carb balance etc. again.
Offline kartin
  • Expat Brit
« Reply #33 on: June 22, 2024, 04:41:12 AM »
So I was about to try the Flickr approach but thought I would try one last time with the devices at hand. Those last 2 posts were done using Safari browser on my iPad.
