Author Topic: Primary drive chain backlash/play  (Read 5420 times)
PikeyBoy
« on: July 24, 2010, 08:57:05 PM »
Well at last I am getting on with the rebuild.
I have today taken the clutch assembly off and noticed that when I turn the primary drive shaft there seems to be a lot of backlash/play in the primary drive chain.
Is there a tensioner on the chain somewhere or do I possibly just need to get a new chain?
Offline lordwhimsey
Re: Primary drive chain backlash/play
« Reply #1 on: July 24, 2010, 09:49:46 PM »
There's no tensioner on the primary chain; if you're taking everything apart it's worth changing it although they're a bit pricey (
« Reply #2 on: July 25, 2010, 09:31:24 AM »
The primary can wear through both the oil gallery from pump to filter AND the main cross gallery so if you have plans to split the cases always fit a new one
Offline Yoshi823
  • Biker to the bone...
« Reply #3 on: July 30, 2010, 05:52:07 PM »
It's a Hy-vo multi link chain & i've heard of engines with 80,000+ miles on them with no noise from the bottom end. The chain can sound as though it's flapping around if the carbs are out of synch.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
