Author Topic: 400 crankcases....  (Read 5091 times)
Offline Matt_Harrington
400 crankcases....
« on: July 28, 2023, 03:51:58 PM »
I maybe overthinking things but whilst platigauging the crank shells, I noticed that the shells sit everso slightly proud of the half bore. As an experiment, I used a little plastigauge on the mating surface next to where the crank shells fit. Torqued down (without the crank) and then revealed the result.
What would you expect to find?
Offline robvangulik
  • Honda Fourever
Re: 400 crankcases....
« Reply #1 on: July 28, 2023, 04:15:46 PM »
0,0
« Reply #2 on: July 28, 2023, 04:32:31 PM »
Was that meant to be 0.0 ?
« Reply #3 on: July 28, 2023, 04:42:00 PM »
I'd imagine a gap at the bottom as the crank pushes the shell into the casing, hence why they stand ever so slightly tall.
« Reply #4 on: July 28, 2023, 04:45:36 PM »
Do you mean a small gap between the 2 small mating surfaces next to the shell housing?
« Reply #5 on: July 28, 2023, 05:03:53 PM »
No I'd imagine right at the bottom of the half circle, where the oil hole is.
« Reply #6 on: July 28, 2023, 05:36:45 PM »
The shells are always slightly proud and turn circular when casings clamped
Offline robvangulik
  • Honda Fourever
« Reply #7 on: July 28, 2023, 06:08:53 PM »
Yep, on the continent we don't point but we comma!
« Reply #8 on: July 28, 2023, 08:01:17 PM »
Damn forigners
