Author Topic: Warm starting issue  (Read 6155 times)
Online Athame57
Warm starting issue
« on: July 28, 2023, 08:27:16 PM »
These past few weeks I've found it very hard to start my engine again if I switch off with a hot engine. Keeping my finger on the starter and closing the choke usually gets me going again....any ideas?
1978 CB400F2 named Elen.
Offline 400 Cafe Racer
Re: Warm starting issue
« Reply #1 on: July 28, 2023, 09:32:46 PM »
If you need the choke to start a warm engine, it sounds like fuel starvation or excess air.
Could be blocked jet(s), restricted fuel flow, vent blockage on tank.  Excess air, could be flexible mounting rubbers leaking etc.
Let us know how you get on. ;)
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Online Athame57
« Reply #2 on: July 28, 2023, 09:44:35 PM »
I'm about to overhaul my carbs as it happens, just bought some bits of Julie  ;) I'll take those things into account and come back with results!
« Reply #3 on: July 28, 2023, 10:35:49 PM »
I would have suspicions about an air leak between the cylinder head and the carbs as my first line of investigation.
Offline Matt_Harrington
« Reply #4 on: July 30, 2023, 10:48:55 AM »
All I can add is that the non OEM air screws (probably chinese) as so different from the OEM ones that they are almost (perhaps I should say totally!) useless.
Offline Mikep328
« Reply #5 on: August 02, 2023, 09:21:06 AM »
Can you get OEM Honda airscrews/other carb hard parts like jets/needles?  I tried to find some and the few places I found them listed they were shown as "discontinued/no longer available."
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #6 on: August 02, 2023, 09:53:35 AM »
Have you tried David Silver? If none there, s/hand is an option....
« Reply #7 on: August 02, 2023, 11:53:03 AM »
Hopefully you should be able to clean up your existing brassware.
I have quite a few good used needles, emulsion tubes etc.
Just PM me if you need anything if yours are damaged - Ted
Offline Mikep328
« Reply #8 on: August 02, 2023, 12:54:28 PM »
"Have you tried David Silver? If none there, s/hand is an option...."
DSS lists the hard carb parts as pattern parts, not genuine.  No idea who the actual supplier may be.
"Just PM me if you need anything if yours are damaged - Ted"
I haven't yet gotten into the carbs but the needles/needle jets on a Norton Commando's Amal Concentric carbs wear and require replacing at, say 20k miles (or less) so I was ASSuming the same is true with these bikes/carbs.  Of course, Norton twins 'shake' a lot; Honda fours don't!  :)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #9 on: August 02, 2023, 02:49:14 PM »
I can't remember seeing any wear issues on the brass ware on the SOHCs, not saying it can't or doesn't happen, I'm saying I personally have never seen it.
« Reply #10 on: August 02, 2023, 04:37:20 PM »
You mean you know of a commando that got to 20k?
Offline Mikep328
« Reply #11 on: August 02, 2023, 04:57:32 PM »
LOL!  Well, not with all-original parts!  ;)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #12 on: August 02, 2023, 04:59:35 PM »
Worst were the last white ones built from spares, like the Triumph cardinal
Online taysidedragon
« Reply #13 on: August 02, 2023, 05:03:29 PM »
Or the 'Combat' Commando engines. ☹
« Reply #14 on: August 02, 2023, 05:06:25 PM »
NRP sell the original Keihin brass ware. But, it's very rare to have to replace any brass bits once they've been thoroughly cleaned, including the emulsion tubes.
http://nrp-carbs.co.uk/
