Author Topic: cb 500 but not to standard  (Read 44106 times)
Offline gary123
Re: cb 500 but not to standard
« Reply #30 on: August 24, 2023, 08:18:11 PM »
I had a little ride up to Graham and Julies place today, got a nice cup of tea and stole some some rare parts, thanks mate.
Also had a look at the number plate mounts on their mongrels. Im not keen on side mounts and did not cut the back end off my bike in the hope of coming up with something.
So on the way back I had a mooch round B and Q and bought some angle brackets. I think this will work but might end up using the brackets as templates for something more substantial.
I dont think they will flex/bend but they might be a bit "bouncy. (already had the light/plate mount)
        [ Guests cannot view attachments ] [ Guests cannot view attachments ] "
Offline gary123
« Reply #31 on: August 24, 2023, 08:26:26 PM »
Stupid camera was in some kind of special effects mode. Corse it could be me. [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Reply #32 on: August 24, 2023, 09:39:38 PM »
Could you fit a bracket on the inside of each of the indicator bolts & attach them to the B&Q strips to improve overall rigidity?
The plate bracket seems a long way off a vertical number plate mount for some level of legality.
Offline gary123
« Reply #33 on: August 24, 2023, 09:47:53 PM »
Maybe, still working on it.
Not sure what the law is, Ill google it.
Offline gary123
« Reply #34 on: August 24, 2023, 10:21:23 PM »
60. Fixing of registration plate
(1) (a) Where a vehicle has been so designed that a space has been provided for the fixing
of a registration plate, the plate shall be fixed in the space so provided.
( Where a space is not provided the plate shall be fixed in the manner specified in
paragraph (2).
(2) Subject to paragraph (3), a registration plate shall be fixed vertically or, where that is not
reasonably practicable, in a position as close to the vertical as is reasonably practical at the front and
rear of every motor vehicle in such manner that the characters of the registration mark shall, at all
times, be visible from the front or the rear of the motor vehicle.
« Reply #35 on: August 24, 2023, 10:37:22 PM »
If you are riding on the A515 towards Buxton from Ashbourne your plate will be spot on for the Bear in the Air that clocks speeders . 8) 8) 8)
I think you need to comply with Para 2 in the unlikely event that you ever encounter the Dodo that was the Road Traffic Department even then it would most likely be just a VDRS ticket!
« Last Edit: August 24, 2023, 10:40:36 PM by McCabe-Thiele (Ted) »
« Reply #36 on: August 25, 2023, 07:47:03 AM »
I guess that the 'reasonably practical' test there is that if it's any more vertical it will foul the rear tyre, and/or break off against it.
My mounting is an angled piece that runs between the two indicator bolts (ie 1 inch or so long, then a 90 degree turn, then runs between the frame rails then another 90 degree turn/1 inch. The 1 inch bits are drilled and bolt to the indicator/ mudguard mounting holes),  so the number plate ends up similar to yours but the mount is fixed between the two ends/ arms of the frame. Doesn't bounce at all.  (It was a bracket from a gas fire that just happened to be the perfect fit).
Offline gary123
« Reply #37 on: August 25, 2023, 09:27:26 AM »
Any chance of a picture, Ive avoided crossing between the indicator holes in case it catches the tyre.
« Reply #38 on: August 25, 2023, 04:31:12 PM »
Nice seeing you mate. My mates dog was not  :o
I would put a bridge bracket between where you have the indicators mounted. This would give extra strength  ;)
Offline gary123
« Reply #39 on: August 25, 2023, 06:04:04 PM »
Yes, still working on it.
Offline gary123
« Reply #40 on: September 05, 2023, 07:52:09 PM »
Well as far as the build goes Im calling it done
It runs OK but needs carb balance and timing tweaking. ( i bought a strobe Graham). Busy with house renovation atm and chasing another pile of scrap to keep me busy over winter.
« Reply #41 on: September 05, 2023, 08:24:03 PM »
Well done Gary 👍👍👍
« Reply #42 on: September 05, 2023, 11:36:52 PM »
Looks a bit different than some boxes of parts. Balance the carbs before you strobe in the ignition and connect the strobe to a independent battery mate  ;)
« Reply #43 on: September 06, 2023, 08:00:52 AM »
Liking the look of that Gary! Nice work!
Offline gary123
« Reply #44 on: September 06, 2023, 09:31:52 AM »
Cheers Graham, will do.
