Author Topic: Honda CB750k2 main jets  (Read 12484 times)
Offline Pauarc
Re: Honda CB750k2 main jets
« Reply #30 on: August 08, 2023, 01:47:38 PM »
Striped carbs needles are 27201 they are on slot 4 from the top
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
« Reply #31 on: August 08, 2023, 06:02:39 PM »
Were in the middle as a factory set  ;)
Offline Pauarc
« Reply #32 on: August 08, 2023, 07:49:58 PM »
Would this make it run rich what do you set them at
Cb750k2
« Reply #33 on: August 08, 2023, 09:52:19 PM »
position 3, middle  ;)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #34 on: August 08, 2023, 11:32:17 PM »
The position you have effectively raises the needle, thereby allowing more fuel in the mix, and as you surmise, richer.
Offline Pauarc
« Reply #35 on: August 09, 2023, 09:26:07 AM »
I think I will change it to slot 3 and I think this should put carb back to standard fingers crossed
Cb750k2
Offline Pauarc
« Reply #36 on: August 14, 2023, 01:12:21 PM »
When out today the bike running the best it has done
Setting on carb are 110 main 40 slow 1 turn air screws, needle slot on 3
Hm341 exhaust, carbs are 657b, Dynas ds1-2kit electric ignition, standard coils
D8EA plugs and sync with carbtune pro,will check the plugs after a good run
thanks for all your help
Cb750k2
« Reply #37 on: August 14, 2023, 01:39:41 PM »
Glad you got it sorted with a factory spec  ;)
Offline Pauarc
« Reply #38 on: August 17, 2023, 01:11:29 PM »
Had a good run out today when down to Mersea and back will have a look at the plugs later running a lot better now
Cb750k2
« Reply #39 on: August 17, 2023, 03:01:10 PM »
Never understood why people get paranoid about plugs, as long as the bike is going well and the plugs are not fouled, i can not see a problem with a old engine  ;)
Offline Martin6
« Reply #40 on: August 17, 2023, 03:56:46 PM »
I was riding the other way to Maldon. That was me nodding to you at the T-junction by the Peldon Rose. Small world! 👍
Offline Pauarc
« Reply #41 on: August 17, 2023, 05:04:22 PM »
Hi Martin
Yes I did see you is it dark red if you are passing through Totham and want a pit stop
if I’m in stop for a chat give me a message
Paul
Cb750k2
Offline Martin6
« Reply #42 on: August 17, 2023, 10:21:10 PM »
